I am looking for advice on how to affix 1/8″ diamter quarter round molding to stairs to hide the crack where the riser meets the tread.
Pin nailer and some glue.
1/8" diameter would mean 1/16" radius. Do you mean 1/4" diameter (1/8 x 1/8)?
Yes, you are correct. Thanks!
I would be a little concerned on why there is a crack, but that aside, if your molding is truly that small no nailer will work. You would have to use some type of adhesive that can bond with finished wood, I'm assuming these are finished wood stairs. My first choice would probably be a thick ACC/CA glue with or without accelerator, followed by a polyurethane like the original Gorilla Glue, but that stuff is messy to work with because of the effervescence and I can't think of any way to clamp it.
By chance have the risers or treads shrunk as it’s winter?
Just wondering if you wait a few months the problem may go away.
If not wood glue can work. I’ve used CA as the clamp and it’s a trick that works. 23 gauge pinner maybe, too.
Be sure to attach to either tread or riser but not both. Seasonal movement and all.
Actually they didn't shrink from winter, the house is really old and they have had a space for a while.
The 23 gauge pinner works well, but the one we have isn't setting the pin correctly despite PSI.
Thanks for your help!
My PC pin nailer as designed set the pins flush with the surface. I filed the nose off just a bit so it will sink them slightly.
