Does anyone have a good way to clamp your stock to the Incra 1000 to provide in/down pressure?
trimjim
You can add an auxiliary fence to it, and put sandpaper on the face of the aux. fence. You could even add a clamp I suppose. What type of stock are you having trouble holding still? In many instances, you'd be best off making a crosscut sled.
When I crosscut using the Incra, I focus more on holding the stock down, and somewhat less on holding it in. The sandpaper-on-aux. fence really helps with keeping the stock still against the fence. This is especially true when you're doing miters or bevels (fairly obvious).
