115v wiring diagram for Delta DJ-20?
Anyone have a wiring diagram to switch from 230v to 115v on a 1 1/2HP Delta DJ-20 Jointer?
I have come to the conclusion that Detla manuals suck! It’s wrong about how to assemble it, it’s wrong on what parts you need/have it’s wrong on the fact that it says that there’s a wiring diagram on the “motor name plate” as my motor doesn’t HAVE a name plate. I even went online to their website where the have a nice little picture showing you a motor and a line pointing to the lable on the motor saying that this is where the wiring diagram is…. except on MY jointer that is.
Can you tell I’m a bit frustrated as I have this brand new toy and can’t play with it?
So… Anyone have a wiring diagram on how to change it from 220 to 115? or can tell me how?
I REALLY don’t want to have to wait until Delta tech support is open on Monday!
Thanks!
Donald
Hey Donald,
A couple of years ago I had the same problem with a Delta 8" pro jointer.
I found the wiring diagram on the inside of the access cover on the motor.
Hope this helps,
Brent
Thanks for the suggestion... unfortunately I'm not so lucky. I already pulled every cover/access plate I could find and no diagram.Thanks though.Anyone else out there with a Dj-20 and a wiring diagram?Donald
