I have a Unisaw from about 1990 or so. It a 10″ saw, of course. Can I put a 12″ blade on it for the occassioal cut I need to be deeper than 3 1/8″? Is this safe? Thanks for your help.
Odds on it won't fit. 1, the center hole is 1" on most 12" blades. 2, the throat plate is not long enought. 3, clearance for the blade under the table non existant. 4, if it did fit lose of cutting power due to larger blade.
It can be done because I know of someone who did it. He had to remove the deflector in the front of the blade and the guard holder in the back. It won't hurt the saw for occasional use.
Thx for the input. Does anyone make 12" blades with 5/8" arbor holes?
I've seen them plus you can always use a bushing. Have you been to the links pages...an underated and often over looked source. Many sites have links...woodcentral.com, badger swamp , the oak, http://www.woodweb.com
Forrest has reducers from 1" to 5/8". I bought a 1" bore Forrest WWII for my Shopsmith. When I sold the Shopsmith, I got the reducer from them so I could use the WWII on my new PM66.
I suggest calling Forrest. The reducer has to be cheap. They sent me mine for free since I bought the blade from them.
That's why this forum is so great. Thanks a bunch. I also have a Forrest blade, although 10", of course. I do have a 12" on my DeWalt chop saw.
Get a band saw.
PlaneWood by Mike_in_Katy
PlaneWood
BAD idea! The motor isn't designed for the extra torque the blade delivers. You'll probably end damaging your motor. To compensate you'd have to reduce the drive pulley size. My advise is don't do it!
Dave
7273.7 in reply to 7273.1
Dave
It won't hurt anything and there is certainly no need to compensate by reducing the drive pulley. We have a 14" griggio and we put on an 18" blade for certain jobs not to mention I know guy who ran a 12" on his unisaw more than s4s plans to. Sears used to sell a 12" saw that was really a 10" but used a blade with a 5/8 arbor.
Rick
I'm with you Rick. Unless he was cutting 4" thick oak day in and day out, even then, I'm not sure that alone would do it either. I certainly would offer caution, but once the blade was up and running, I don't see it as a problem. I certainly see no reason for changing a pulley out for occasional use. The tip speed would be a bit faster, but other than that, I suspect a Unisaw can handle it.
Hell yeah!!!!!!!!!
Go ahead.
