I have a 12″stand alone planer on casters and was thinking about switching to a 15″ that runs on 220 and weighs 340 lbs. Considering the drawbacks of a dedicated circuit and weight, if the 12″ is working ok is there any real good reasons to switch?
What made you think about switching in the first place?
David Ring
Nope.
If I could afford it I would have both, The 15" for sizing since the CPI is much lower than the 12". The 15" Bad boys are much more durable and will last for years and stand up to the heavy use of roughing. And a DeWalt 735 for finishing.
Bruce S.
I'd rather use a L-N 4 1/2 for the finishing, works better and there are these nice long thing shavings all around the bench.
I would really like to be able to use a plane more often myself, But two herniated and squished discs in the lower back limit me. That slight bending over posture for a short period of time will send my lower back into spasms.Work Safe, Count to 10 when your done for the day !!
Bruce S.
I always have trouble plugging those in. Nice paperweights, however........ :-)John
What 15" machine are you considering? 340 lbs seems awfully light.
John
delta dc380-15" used
OK, that's the one that I have that is my friends. John
I own a 12 inch Parks cast iron planer. This is the format/planer that Fine Woodworking chose to publish how to tune a planer that had ALL the features an excellent affordable planer had to offer. It's components and design were the same as 24/7 industrial planers. This 12 inch machine has survived the test fo time. My suggestion is to sell your present 12" planer and go to E-Bay and buy a Parks 12" planer and never look back. The only comparable planers are Olivers from the ol" days. You are talking about 3" wider. Consider instead the quality of older machines no matter what the electric requirement is.
