I have been using my drum sander for finish work for many years. However there is a problem that I have not yet solved. How do I keep the buildup on the abrasive from making marks on the finished work? I clean the surface often with the cleaning bar,but,this does little to remove the lines of buildup on the sanding surface. The suggestion that the belt be washed in a thinner has not worked for me. Any help that you may give to solve this problem will be greatly appreciated. Work safely ¬¬¬¬¬¬¬¬¬¬PAT¬¬¬¬¬¬¬¬¬
Hi Pat,
You didn't say what kind of material you're running through the sander. If you're getting glazed streaks on the sandpaper it's time to throw it out. This has happened to me when I've forgotten to scrape the glueline on a panel and run it through. Slightly green or resinous wood, like knotty pine, could cause the problem as well. The marks I would get are burns caused by the glue/resin buildup.
Again, the only thing I have found to get rid of this problem is to put on fresh paper.
Paul
I make it a practice to never pass any glued up pieces through the drum sander unless they have gone through the planer first. Any little glue residue will foul up the sandpaper. Also I do not put pine or woods with a lot of pitch through the sander. Sometimes a piece of wood with a large knot will foul up the sandpaper.
