2 flute straight router bit with a 4″ cut length?
Hi All,
Does anyone know where you can purchase this? Magnate used to sell them but it is discontinued, I use these bits for 3″ thick tabletops that have been cut to rough size, and need to trim them flush and square.
Thanks.
Wow, that’s big for a hand held router. Why not just use a top bearing bit to get you half way (template on the top) and then a bottom bearing bit from the underside to make it flush with the first cut? 2 bits and 2 cuts, but less likely to have it run on you or snap a bit. Routerbitworld.com sells double and triple fluted carbide bits.
agree w/ above
I agree w/ the guy above
Try Wisconsin Knife works, I believe they make a bit like this, I do like the other suggestions though, thats an awfluly long bit.
Good luck
Thank you all for your helpful replies!
