Hello to my fellow woodworking artisans and weekend warriors. I found myself thinking about all the stuff in my shop today. Some I never use but bought for some specific reason… Some I use every day. Some others are what my question concerns. I have a number of “non-woodworking” shop tools I just love to use in my shop. My favorites are the following items:
- A NUMBER 2 PENCIL THAT HAS A SOFT, BUT NOT TO SOFT, FAT ERASER.
- I use this for holding down and pushing small items through my table saw. I do not even have it sharpened!!. This little “tool” is great!
- AN EMPTY CLAUSEN PICKLE JAR, QUART SIZE __MANY!
- The wide mouth and good seal are perfect for storing varnishes and various 50/50 or 60/40 varnishes
- A BUNCH OF COFFEE STIRS
- For cleaning glue press in corners and inside angles of miters is perfect. Straws seem to be to flimsy
These are my favorites. What do you use that I and others might find useful and not expensive????
Rich
Ever try a foam brush with the foam stripped off? Makes a great glue spreader.
How about emory boards as detail sanders?
I have not tried it yet, but I will thank you!!
I also Forgot another favorite!!! Rubber bands!!! for clamping small boxes etc...
Rich
TG,
Non woodworking shop tools...here are a couple. Well they were a couple until yesterday when one was sent to the happy mousing grounds by a marauding kiwi driving a car.... The rage remains but the pain has lessened by the arrival of a new recruit-too shy to be photographed just now.These "tools" maintain good humour in the shop and kitchen.
The other pics show some markers/scribersknife edged and pointed made from darts-cheap .
Many items fitting your specs are to be found in my shop-these just surfaced from the murky cyber depths.
Excellent idea about the darts! I think I have a few old darts some place and I will be converting them soon. Sorry to hear about your "guards". I too have a little solider guarding my shop that appears to spend most of his time in the saw dust....
Rich
Sorry, first Pictures I Posted where bigger then the cat itself!
Rich
Definitely a fine figure of a cat! What is his heritage?Mine are Tonkinese-which is Burmese Siamese cross-now a registered breed. The new recruit is a charcoal version of the chef. The chef hates him for now, but I detect a softening up process beginning.Philip Marcou
I use the Credit cards and similar cards that get sent asking you to apply, as glue spreaders. I also use the trick of stripping off the foam on used foam brushes for that purpose. I use cleaned popsicle sticks ( or craft sticks ) for that as well and mixing epoxy, holding finishing nails away from my fingers and other uses. old baby food jars, 1/2 pint canning jars... I also like the emery board for tight sanding spots.
My pocket knife sees a lot of use. An old rolling pin works nicely for applying veneer.
I took a stiff-bladed putty knife, ground a very slight curve across its end, and used a burnishing tool to roll a burr; it's a very functional handled scraper that works well for shaping wood and removing glue.
-Jazzdogg-
A large, removable cannister pencil sharpener mounted to a shelf like the one Mrs. Baggett had in her 1st grade class back in 52'. With the cheap pencils made today, you want a point; you get the point quickly!
SARGE.. g-47
Hi Sarge,<!----><!----><!---->
Thank you for participating in my little discussion.<!----><!---->
I read somewhere to fill bug holes, you just use the same wood with as the natural hole is in a pencil sharpener like you described, and then tap the sharpened point into the hole, cut off and sand. Bang no more hole!. I have not tried it yet and like the natural holes, but it should work<!----><!---->
Rich<!----><!---->
Cheap Choo-Choo sander from HF&T with custom pads for sanding large quantities of custom moldings.
Dead-Blow Hammer for general persuasion and driving bench chisels.
Dental irrigation syringe for filler and glue injection.
Playing cards for shims.John O'Connell - JKO Handcrafted Woodworking
The more things change ...
We trained hard, but it seemed that every time we were beginning to form up into teams, we would be reorganized. I was to learn later in life that we tend to meet any new situation by reorganizing; and a wonderful method it can be for creating the illusion of progress while producing confusion, inefficiency, and demoralization.
Petronious Arbiter, 210 BC
My boys call my dead-blow hammer The Persuader.My goal is for my work to outlast me. Expect my joinery to get simpler as time goes by.
That's a clever idea rich, Rich. I bet it would work also....
Regards...
SARGE.. g-47
TG
used auto wiper blade for spreading grain filler
Excellent idea!!! I need to change mine I will keep them to give it a try
Rich
I got a set of five artists brushes at the dollar store. These are the best glue spreaders and if you rinse them after use, they last a long time. Art
The small plastic tubs from I-Cant-Believe-Its-Not-Butter. They're the perfect size for holding small amounts of glue (either in the tub or on the upside-down lid) and dipping the glue brush into. I also use them a lot for wipe-on poly - they hold a decent amount and the opening is a good size for dipping the rag into it. They also work well for temporary small parts holders. If glue or finish dries inside, you just give it a squeeze or two and it flakes right off from the plastic.
If you build it he will come.
