I’ve been using the Veritas 32 system jig to make 32mm cab panels. My results have been a bit mixed. It take a while to set up but when it is, the drilling goes pretty fast. The main problem I have is, even with a good sharp brad point 5mm bit with spades, I get tearout in maybe 20% of the holes. I’ve used both a 12V cordless with fresh batteries and a much more powerful corded drill — similar results.
My questions are: would an entry level line drill give me reliable clean holes? What is the price range for a decent one? Who are the quality manufacturers?
-robert
EDIT: I believe I used the wrong term above: the 5mm drill bits I’ve been using (from Lee Valley) have brad points and spurs.
Edited 10/31/2006 2:38 pm by ram
If you use a plunge router with a plunge bit to bore the holes, there is no tear-out. The bit turns so fast that there is no time for the wood fibers to tear. I don't know that particular jig, but I'll bet there's a way to use it with a plunge router.
Great tip, thanks! -robert
"I've used both a 12V cordless with fresh batteries and a much more powerful corded drill -- similar results."
The question is, at what speed? Most cordless drills can't do more that 1,400 rpm. At lot of corded drills peak at under 2,000rpm. A point-to-point (industrial) borer runs at somewhere between 3,000 and 6,000 rpm. If you have a compressor, even a small one, your drills could be drilled much more cleanly using a 3/8in air drill - many of these peak at 2,600 or even 3,000rpm and cut much more cleanly. You'll find they're better on pocket holes, too.
Scrit
Sounds simpler than puzzling out a plunge router adaptation for the jig. Do you have suggestions of who makes a good air drill like you described?
Thanks! -robert
The first thing I would try would be to hone the spurs on the brad point drill you are using. A cordless is generally too slow, but with even a cheap corded drill, you should be able to get a clean hole with a sharp bit.********************************************************
John Wooden 1910-
Well for a quality tool there's Chicago Pneumatic, but they are a Rolls-Royce quality with a price tag to match. Personally I just use relatively low-cost Chinese/taiwanese drills from out local equivalent to Home Depot (my 3/8in drill cost circa $45)
Scrit
Dear Ram,
What material are you drilling? I have an entry level line bore ( Delta) and the don't turn all that fast and I almost never get tear out. The only time is when I am pushing the machine too hard.
Best,
John
I'm drilling B-3 grade 3/4" birch plywood for the most part. -robert
EDIT: BTW, how much did the delta line bore set you back?
Edited 11/2/2006 2:23 pm by ram
Dear Robert,
I am not sure what grade B-3 is, but Birch ply is what I drill all of the time. (A1 & A2) I think that the whole mess ran me around $1400.00. I have had it for about three years and I'm sure that prices have gone up.http://www.toolsplus.com/del32-325.html1) Line Bore
2) Stand
3) Mobile base
4) Foot pedal attachment
5) BitsFor me, it is a necessity as a hand injury has resulted in quite a bit of loss of feeling so, drilling individual holes, is not much of an option anymore. The machine is very good, although loud to my ears. A lot of gear noise. The only trouble that I have had was with the main shaft loosening up. A little dab of "locktite" on the set screw cured that. One thing that is wonderful to me is that there is almost no setup time. I just walk over to the machine, light it up, drill a bunch of holes, and I can keep going. BIG time saver. Oh, and they are always spaced correctly! (Unlike when I used do it) I use 1/4" bits although 5mm seem more the standard. I use it professionally, and I am not at all patient with "junk". It's no Rolls Royce, but it does its job well. Let me know if you want any more info.Best,John
Thanks a million, John, that's a lot of great information! -robert
Dear Robert,
My pleasure. I'm not sure if it makes any difference to you, but "Tools Plus" is running some kind of special next week.http://www.toolsplus.com/tool-a-rama.htmlBest,John
