Looking for the smallest practical try square. I’ve seen 10½”, 7½”, 7″, …and 5â…”.
Why is 5â…” a useful size?
What is a good size square–small enough so it’s not cumbersome to keep on hand and use, but large enough to be reasonably accurate?
Janet
Janet
Squares
I have several small squares ranging from all-steel engineers squares to combo squares to the standard rosewood/metal try squares. I find the one I reach for most is a 4" double square that I got from Lee Valley several years ago. The same type of square is available from Woodcraft and other suppliers. It fits nicely in an apron pocket, its useful for measuring, marking and layout and it is more than accurate enough for anything I'll ever do while woodworking.
http://www.leevalley.com/US/wood/page.aspx?p=44279&cat=1,42936,42945,44279
Ron
How to make the engraving stand out?
I bought a used 6" combination square, but that may have been a mistake. One side has a lot of fine scratches parallel to the engraved lines, so it's hard for me to tell them apart.
Also, the numbers don't stand out enough. What do you use to re-black the engraving?
Janet
Engraving
I've never thought about doing this but the first thing that popped into my mind was black shoe polish. Rub it into the surface, let it dry and then remove the excess wax. If it doesn't work, just clean the rule with turpentine and move on to the next idea. I'm sure you will get severeal more reasoned than this one!
Ron
I just bought a Nobex and must say it's pretty nice. They collapse flat for easy storage and have eight positive positioning stops for accurate layout. Here's a link http://www.rockler.com/product.cfm?page=9950&filter=nobex
Apparently they make three different sizes but Rockler only carries the 6". I bought the 12" version off ebay for $25.00
double post
can't delete ... ????
i have the incra tiny t and i love it its very accurate and small its a total of like 4 inches and the fence is ajustable. just get a few .5mm mechanical pencil because the marking holes are tiny heres a link.
http://www.woodcraft.com/Family/2000443/2000443.aspx
chris
link wouldnt work
if u want to see it go to woodcraft and type in tiny t-rule in the search bar and it should be the only thing to come up
small tri-quare
I carry a 6" x 3/4" tri-square in my pouch, both at the jobsite and in the shop. This is the most handy and useful size for me and fits easily into the pouch. I have larger ones in my tools box when needed. I also sometimes carry a speed square in my pouch, depends on what I'm doing.
Working at jobsites as a finish carpenter or cabinet installer, I wear a single pouch. It usually contains: small tri square, tape measure, three or four sharpened pencils, razor knife, nail set, side cutters, phillips screw driver and maybe a hammer in the loop if I'm not kneeling down. Sometimes I've got my cordless drill/driver hooked to my belt. I'm carefull not to have too much stuff hanging off of me, don't want to scratch the work.
Bret
I guess for me it depends
I have a 3 piece engineers squares set from woodcraft that I really like. If I'm preparing rough lumber I like the small engineers square to do a quick check off the jointer. If I'm checking the inside of drawers I like the larger square in the set. I recently purchased a pinical larger square for doing larger boards etc . I recently purchased a larger square from penacle at woodcraft thats made real well. And finally I have a starrett framing square for looking at larger panels any ply.
http://www.woodcraft.com/Product/0/18896/Pinnacle-Precision-Square.aspx
The one Use the most is that little one from the 3 piece set from woodcraft. It fits so nicely in the pocket.
Janet,
I think every well equipped shop needs at least three (maybe four) sizes of squares. As many of the posters have already said, the smallest (4-5inches) are the most often used. I have a 4 inch sliding combination square that is Always in my shop apron right hand pocket. But there are times where a larger 6-8 inch square is needed ( think checking inside a drawer before the glue sets) I keep this in the top drawer of my workbench, and an even larger 12-inch square for marking out plywood -this one hangs on the wall. I also have a good quality carpenters framing square (16"x24") for larger layout of sheet goods, and it really sees very little service compared to the smaller squares - I think it is stored near the saw-hourses. I even have a large tee-square (24"x48") that I thought I would use for marking large sheets of plywood - it hangs high on the back wall of the shop mostly collecting dust.
If your starting out, buy the smallest one first, then go bigger later. The smallest squares are the most used.
Robert
Are the squares that don't have moving parts more accurate than the adjustable ones?
Janet
hi janet,
that's a question i've often pondered. i tend to trust a fixed square over a sliding combo. the mitoyo combination square, in my shop, is as fine a tool as can be, but i reach for a fixed square, over it also. i am also more nervous about banging into things or dropping my combos. it just seems that the more moving parts a thing has, the more that can go awry.
eef
these are the four I use the most with the little one being my favorite in my pocket choice for quick checks.
Just an old stand-by
I use just an old Stanley, for the smaller jobs. A picture of this small guy:
Name on the square is Stanley Handyman, just under 6" long.
A hybrid ( http://patwarner.com/try_square.html ), mostly transparent, can be used for setup & scribe.
