Where can I find 5mm carbide brad point bits (sold by the piece)????? I am in Southern NJ (For my drill)
Thanks, Lou
Edited 2/13/2007 3:23 am ET by loucarabasi
Thanks, Lou
Amana is but one of many that sells such tooling. You need to start reading the catalogs. You sharpener should know of such tooling.
Dimar makes them.Also I find that the most common, both clockwise and anticlockwise rotation are made for euro boring machines.They do however have a shank size of about 10mm
Just FYI - Dimar is Amana.
David Ring
CMT makes a wide variety of bits including 5mm, 5.1mm and 5.2mm,with 10mm shanks. Check out your local dealer or order on line. The link below is to Mikes Tools, Mike has good service and a good selection and he has special ordered items for me that were not on his web site.
http://www.mikestools.com/cmt-dowel-drill-bits_1566.aspx
http://woodworker.com/cgi-bin/FULLPRES.exe?PARTNUM=896-545
If you build it he will come.
Lou: I like the selection of bits of all types at Carbide.com: http://www.carbide.com/
Duke
"... Buy the best and only cry once.........
