I’m almost ready to buy my first dado set for my 10″ Delta tablesaw, but am wondering whether to get a 6″ or 8″ set. Not sure I see the need for an 8″ set butwould like other opinions.
I have a contractor's saw, which most recommend using a 6" dado set and not going up to the 8" due to the lower HP of the contractor's saw. As I typically do, I ignored this advice and got the 8" and have never had a problem with it. I've cut some pretty deep dados and slots with it, a few times to the blade's full depth. (A fast way to make doors w/o fussing with true mortise/tennons.) I also use the outside blades with spacers between them to cut tennon cheeks. I've often been glad of the extra inch for that purpose alone. YMMV.
Mike Hennessy
Pittsburgh, PA
The 6" is easier to spin, but you give up 1" of cutting height...which you'll rarely need with a dado. So either works, buy the better deal.
Bill,
If your saw has the power, go with the 8" because it is more about mass than cutting depth. The mass of the blades and cutters have less chance to distort than with the smaller diameter. I would use a 10" set if they made one.
Terry
Terry: Forrest has 10, 12 inch dado sets. Kinda expensive but none of their products has ever disapointed.
http://www.forrestsawblades.com/dado.htm
DukeSupport the Troops, Support your Country
Support Western Civilization:
Fight Islamofascism
Duke,
I know, I talked to the service guy at Forrest and he told me about the mass of the blades. The problem is I bought a 8" Forrest Dado King about 6 months before I bought my Laguna TS, which can handle a 12" blade. I have 2 10" WWII and a 8" dado king from my old PM66, but I didn't think I would gain that much for the money. Forrest said they can make a 12" WWII with a 5/8" arbor for my saw, but I don't think it is worth it. If I need to rip something thicker I will use my 18" Laguna bandsaw with that resawking blade. It is great.
Terry
P.S.
I like you signout. I wish everybody in this country felt the same way.
Edited 3/31/2007 7:54 am ET by terrylee86
Terry: Thanks, I have put my feelings on my sleeve so to speak and appreciate the occasional thumbs up. I live in Berkeley California so such sentiments are not well tolerated here in the so called home of "free speech". I have the same band saw & blade, recently tried to rip a bunch of maple for a cutting board and had to do a lot of hand planing to get ready for glue up. Probably my technique and I needed the hand plane practice anyway.
Fight Islamofascism
Duke,
I live outside of Ann Arbor, MI. I know exactly how you feel. The two hotbed of the 60's.
Terry,Mass is really not a factor. Stacked dado sets have chippers that are sized to increment the cut. A 1/8" chipper has a plate that is 1/8" thick, a 1/16" chipper has a plate that is 1/16" thick. So a 50" dado would have the same thickness chippers as a 6" and the larger the diameter relative to the thickness of the blades the more flexible they are. Therefore the 6" is less likely to distort than the 8" or 10".In terms of power requirements, as the diameter increases, the torque required also increases. An 8" dado requires 1/3 more torque than a 6" and a 10" requires 2/3 more torque.
Charles M
Freud America, Inc.
That is what the guy from Forrest told me at a show. Doesn't matter 6'' is too small and 10" is too big. Maybe the three bears said that.
Edited 3/31/2007 4:22 pm ET by terrylee86
That's a gutsy thing for him to say. It is up to the saw manufacturer to determine the maximum dado size that can be mounted.
Charles M
Freud America, Inc.
Well, I went out and bought a Freud 8" dado set. It was only $20 more than the 6" set.
While going through the Jet catalog I noticed that it says that an 8" dado up to 13/16 can be used on the 1 1/2 HP contractor. Can you explain their reasoning ?Work Safe, Count to 10 when your done for the day !!
Bruce S.
Jet will determine the maximum that can be used on their saws. If they say that an 8" is okay that is up to them. Unless they say that you can't use a 6" I would still recommend it unless you just absolutely need the extra depth.
Charles M
Freud America, Inc.
Thanks for the info. I rarely dado over 3/4" anyway.
Bruce S.
Edited 3/31/2007 9:27 pm ET by BruceS
Edited 3/31/2007 9:28 pm ET by BruceS
