Because of the size of my shop I normally cross cut plywood with a circular saw to get “close” to size then clean up on my table saw. My question is, what saw blade are you guys using for a hand held worm drive circular saw when crosscutting plywood? I realize the Festool is probably ideal but I do not want to spend the money at this time.
Thank you in advance for your feedback.
Erik
I use a Porter Cable Saw Boss with a Porter Cable "RipTide" thin kerf alternate top bevel blade with 40 teeth. My saw is different than yours, but I think the principal still applies. PC makes the same blade in 7-1/4.
I too have put off the Festool purchase and originally set out to get "close" using the circular saw and then go to the table saw. After making a plywood guide and developing a steady feed rate, I began making my final cuts using the circular saw and eliminating the trip to the table saw. I set the blade depth so it was just deep enough to make the cut. I was happy with the accuracy and smoothness of the cut.
Edited 3/21/2007 10:47 pm ET by Quickstep
Erik, I found a $10+ hitachi at lowe's wrapped in a piece of split clear tubing , it's a little funny looking and so sharp ya gotta be careful with the fingers. On my skill #77 it cuts 3/4 ply like butter, buy two. Paddy
Before I got a Festool set-up, I used this Forrest blade in my CS for cutting plywood sheets with a shooting board:
http://tinyurl.com/2rxa8l
John Wooden 1910-
Makita hardi plank blade. Not cheap but cuts very smooth with little tearout.
For clean cuts the worm drive with the smart base from eurekazone.
The base comes with 2 sets of antisplintering zero clearance incerts.
Even a 24 teeth blade gives you clean cuts with this setup.
http://www.eurekazone.com./products/detail/smartbase.html
For long cross cuts the worm is better than a sidewinder (longer reach)
david
I have the PC left blade model. Its a personal preferance I like worm drive saws, I'm left handed. For the blade, I use the Forresst WWII. Its the smaller brother to the 10". It cost more than the standard blades, but I use saw horses and a good strait edge, combined with the Portercable, and my edge cuts are glue ready. In My opinion its a fantastic combination. Thats my two cents worth. Good luck on the decision.
Thank you all. There seems to be several viable optoins for me to improve on my crosscutting with a circular saw. I have purchased a new blade and will give it a try. If that fails I think I will try the smart base and insert. I will post results.
Thanks again for all the tips.
Erik-
