My daughter-in-law wants a 84″ x 34″ art table with only one drawer. This drawer being 24″ x 18″ in the middle. With normal trimming and 4 legs will this be enough to keep it from sagging? With two granddaughters in the house it could turn in to one giant universal table. Biggest table I have made is 4′ long. Suggestions
jake,
I'm not sure I know what "normal trimming" is. I'd want to put aprons 4 to 5" wide between the legs. 1" long tenons into the legs; cut out the opening for the drawer. Stub tenon the drawer bearers into the aprons. Screw the aprons to the top, with alowance for seasonal movement.
Thanks, normal trim 4-5" apron. I just needed reinforcement.
Condsider where the legs are. If at the ends, 84" apart, you'll need considerable strength with aprons and possibly some steel angle underneath to resist sagging.
But if you put the legs each 1/4 of the way in, 21" from each end, then the span is halved, and the support can be halved too. And with around 40" between the legs you might want to give her 2 drawers instead, to use up the space. One for each granddaughter, perhaps?
Hope that helps.
Dave B.
If you used a 3/4" honeycomb core and 1/4 skins for a substrate and veneered the top you could get away with 2 1/2 - 3" aprons and it should be plenty sturdy. I jst did a dining table that size and the top is very stiff although it is in two peices o allow for leaves. There is essentially no apron support at all.
Tom
Douglasville, GA
