I have an old 9″ Rockwell/Delta tablesaw. First does anyone know what size/speed motor it should have on it? Second, I am planning to redo my kitchen,can this saw handle making new cabinets or should I look for a bigger,newer saw. Any input would be appreciated. Thanks
I also have a Rockwell 9" contractors-type saw. Currently I'm running a 3/4 HP 220V motor at 3450 RPM with the blade spinning at about 3600 RPM. I run a Freud thin kerf blade most of the time. I've replaced the original twin tube fence with a shop built t-square fence, and replaced the mystery metal pulley on the motor with a Browning cast iron unit. I use mine daily for ripping cedar chair parts and can't really say a bad thing about it. Well, the one or two times I carried it across the yard I said bad things, but for a tablesaw, heavy is better.
As for upgrading to a bigger/newer saw, you have to consider what you need versus what you're willing to spend. Do you have the space and the jack to bring in a Unisaw or a PM66? Are you willing to spend a little time getting to know the Rockwell and do some work on it? $800.00 will get you a pretty good factory fresh offshore contractor saw, but $400.00 will get you a decent motor for some solid American iron.
-d
Just read your post on the 9" saw.
I have the same saw, used it for 10 years building cabinets and general use. Never had a problem building anything that I needed to. Sure a nice big saw would have made the job easier but I still got the job done.
My original motor was a 1 horse, when that went bad I upped it to a 1 1/2.
Havnt used the saw in a while now but I guess I could if needed.
Doug
