Anyone have any ideas for a finish for a boot bench made from fur?
If the fur is properly tanned, you just have to brush it lightly.
jwtk,
I would think brushing the fur now and then and perhaps a dry cleaning if soiled.
Sorry couldn't resist
Do you want a clear and natural or a stained finished look ?
You could use several of many wipe on products , Tung oil type or maybe a poly type .
regards dusty
These guys are "bad"!! Just a nice wipe on varnish finish--LOTS of coats for durability. ;o)
Mink oil.
Pearls would be an understated, but elegant, option.
Edited 1/19/2009 3:57 pm ET by TaunTonMacoute
Ok Ok
I guess I should have been a little more specific. And check my spellingh. The fur is FIR, vertcal grain Fir as in Wood like Douglas Fir.
Just,I'm in the process of cutting down and modifying a church pew for a boot changing bench in my son's back hallway. His wife would like it dark so I used Bartley's dark mahogany gel stain and it looks quite nice. I'm debating with myself over poly or wiping varnish, wither one will do...i think.
BG
could you post a pic?
Just,I'll try to grab a picture. My wife got a camera from Santa...lets see how dust affects it? I'm still working on the sled base and then I need to varnish
Just,I just finished touching up a few spots on the bench with Bartley's. The bench has not been varnished yet, tomorrow. Here are a few pics, I apologize for the pic sizes.
You're going to wipe this down well with mineral spirits, aren't you? ;o)Gretchen
Gretchen,
Yes, it'll be wiped down well before the varnish. The piece has been just siting there while I've been futsing with the sled feet.I'm not sure where the dust came from, I keep my shop spotless :)
Just an FYI--poly can be a wiping varnish. If you buy wiping varnish then you have paid double for the varnish since it is just diluted poly.
Non-poly varnish can give a lovely finish--in the wood. Just as durable.Gretchen
Gretchen,I'm cheap when it comes to finishes, I learned to make my own wiping from you and others a few projects ago, thanks. What I thinking about now is if I can use up the contents of three cans of varnish to complete this project. Do you see and problem applying oil based poly/gloss under wipe on oil based satin. In other words, do I need to cut the poly into a wipe on?
I would rather wipe on 8 coats than brush 3!! ;o) I know many get a satin final finish by using gloss up to the final coat and then putting on a coat of satin so it should work. Do a bit of sanding between the 3rd and 6th coat.Gretchen
I attempted to shellac a pine marten once, but the &%#* wouldn't stand still for it ;)
(Yes, I know I was a little late to the party, but it's really hard to pass up a punny opprotunity)
Verne
If a tree falls in the forest, and no one is there to cut it up and make something with it . . . what a waste!
Well fur heaven's sake! You shouldn't put ANY kind of finish on FUR... it'll make it stiff!
