Just old barn wood, milled up into a chest of drawers. A few pictures to look at, as well. That shot of the opened drawer shows off the dovetails cut with my homemade dovetail template. About three good days to make. Top sits in a frame, and a plywood panel fits in the frame. Stain is more of a glaze to even out the grain. Handles came from a Dollar General “grab bag”. Any questions?
Hey Dog,
What a great chest of drawers from reclaimed barnwood. You keep this up and Obama is going to give you an award for being such a recycler. Great work.
Good use of wood
Construction is similar to early golden oak furniture -
We have a few older pieces in that style we restored and they have stood up well with my Family -
Thanks for posting
SA
Just the way i do things
This system of chest of drawers has worked for me for quite a while. Rather than deal with solid ( and moving) panel sides, a frame and panel system works better. I've used just regular pine, this old barn wood Doug. Fir, Pallet wood oaks, and a few other woods. Some may use a groove along the posts to install the side pieces, I just use a rabbet. The rest of the pieces then just get nailed and glued in the rabbets. Sometimes, a piece of 1/4" plywood is used as panels.
I use web-frames for the drawers to slide on, no metal guides are used. Face-frames are just long enough to go between the two front posts, and wide enough to cover both the web-frame edges and the kickers, about 1-1/2" wide. Top and bottom face frame pieces are a bit wider. Top one is usually 2" wide, and the bottom one is wide enough to allow for scollop work.
Mostly 3/4 overlay drawer fronts, one this one I used flush fronts. A stop of sorts sets how deep the drawer goes into the case. I set the drawer depth by adding a screw into the backpart of the web-frame. Drawer hits the screw when the drawer is closed up. A few more pictures:
Sold!
Not long after I made this, I put it out for a yard sale. More of a way to draw people to the sale, making some "Drive-bys" actually stop and look around. A fellow looked the chest of drawers over. It turns out he was just back from Iraq, got married and was looking for furniture to set up housekeeping with. I asked him IF $30 was too much. "NOPE!" came the answer. Now this Marine has a hand-built piece of furniture to start his married life with.
