I am making my first stick and cope doors for a bathroom cabinet and could use some advise. Since I will be setting a mirror into the door in place of a panel, my thinking is that the extra weight of a 10 by 22 inch mirror will tend to rack the short tennon in the cope and stick format.
For that reason I am planning to add floating tennon to the joints, which, at an inch long (the maximum length of my 1/4 inch spiral bit) will give me tennon half an inch longer than the stub tennon from the coping bit (sticking bit? I can’t seem to keep that “bit” straight).
One of my friends has suggested that the effort to do this isn’t worth the effort. Has anyone else experimented with adding floating tennon to this type of door rather than simply building the frame the old fashioned way with full tennon?
It is worth the effort and is definitely very easy to do. I cut the mortises with a 1/4" solid carbide spiral up cut bit to 1" depth before I route the cope and stick. I use the Microfence edge guide with an extra guide on the opposite side so the pieces are captured and bit wander is impossible. I use the Tage Frid simple mortise box to hold the pieces being careful that the face side is always to the edge guide side. I use 1/4" MDF for the tenons as it is a perfect 1/4" and plenty strong for these tenons. It increases the frame strength for heavy applications. For good measure, I add an 18 gauge, 5/8" brad using my Senco nailer to each mortise through the back side of the rails and stiles where the loose tenon resides.
Thanks for the response. I was hopeing that this would work.
Where might I find a picture/drawing of the Tage Frid simple miter box?
Here are several url's that explain it. It is marvelously simple and works great.
http://www.taunton.com/finewoodworking/SkillsAndTechniques/SkillsAndTechniquesPDF.aspx?id=2066
http://www.highlandwoodworking.com/index.asp?PageAction=Custom&ID=29
And here is the refeerence to the double sided edge guide. I always got some bit wander with multuple plunges using a single edge guide. The double edge guide totally eliminated bit wander so I get perfectly aligned mortises every time, especially important with cope and stick joints. I got the idea from Pat Warner's site but used my Microfence on one side, bought longer guide rods from Microfence and made my own second edge guide using Pat Warner's idea. I use the double edge guide with the Tage Frid mortising jig above because the whole setup is so stable. It works so great!
http://patwarner.com/double_edge_guide.html
Well, I'm happy now. I've printed both the references out for more leisurely reading.
Thanks for the url's as well. I haven't previously seen either of these two sites. I expect that I'll prowl them for a few evenings to see what else I can learn.
Thanks again.
Hey Mike,I've no new references for you but, I'm in the process of making three entry sized doors for my finishing room, one with a full length wired glass panel. I've used floating tennons throughout, and so far, It's stronger than necessary, and was easily done.Tom
Well here's another question regarding floating tenon. Broad side to mortise fit vs. narrow/curved side to mortise fit.
I know that having a tight fit along the broad side of the floating tenon and it's two mortises is very important.
Is it as important that the narrow or rounded side of the tenon fit into the mortise without any play at all as well? It is clear that making the broad sides fit tightly is not that hard. It is quite a bit harder to fit the curved narrow sides of the tennon to the curved sides of the mortise. The temptation is to leave that portion a little loose.
What say you, O ye wise ones?
That is a detail that I have not sweated. Given that I use the floating tenon to reinforce a cope and stick that already has some glue surface to it, I get close but don't worry it it is perfect. As I mentioned earlier, I add a a few 5/8" 18 gauge brads from the back and it will never ever come apart. I do take the time to round over the edges on the 1/4" MDF so it is a fairly good fit but don't worry about perfection.
Great, thanks!
I use floating tenons on all doors. I use a power hollow chisel mortiser so the corners are square. A long length of tenon material is cut on the table saw to exact size. I make the mortises after I do the coped edgeswhich means the depth must include the width of the cope overlap. A friend uses an FMT to make the mortises and uses a long bit to make the tenons. They fit beautifully but of course he can only make one tenon at a time.
Cheers
OK, I'm slow this morning - - FMT?
I can see where using a hollow mortiser would simplify making the stile mortise, and the square ends makes making the tenon fit much simpler, but how does one use a power hollow mortiser on the ends of the rails?
you deserved to own one Hermes Bags
you deserved to own 1 Hermes Bags
Correct option here of herems victoria, discount hermes bags, herems victoria bags herems victoria handbags. Hermes victoria is indeed charming that most girls around the globe are delighted with owning it. It's really simple for carry and comfy, not losing elegant and style taste. This makes it definitely versatile - to be applied each day or for traveling. For those girls who owns Kellys or Birkins and hate to lug them about in airports, the Hermes Victoria Bag is a fantastic option. It is actually roomy enough for hand-carry and can also be employed as getting an on a daily basis bag. Our Hermes Bags shop with very affordable rates quickly totally free shipping on all orders!
Appropriate decision here of hermes birkin handbags, cheap hermes bags, low-priced hermes birkin bags, discount hermes birkin handbags. Hermes birkin Handbags, French high fashion handbags that occur to become primarily manufactured from leather. The number one luxury which females really should own in their lives, basically by far the most favorite of numerous stars, nobility, ladies, lots of men and women searching forward for the earth's most well-liked handbag. Hermes birkin Handbags are hand-built by skilled craftsmen, a single of your main aspects major towards the good quality. Using a 170-year record of supplying the planet with much more luxurious leather goods, Hermes birkin Handbags have earned their reputation because one of the most sought-after handbags of all time. Up to now, Hermes birkin Handbags remain enduring illustration showing classic beauty, lasting style and timeless design, ladies' favorites. You should acquire your easiest favored hermes birkin Hermes Bags here. All top rated high quality, excellent deal.
Choose one on the hermes evelyne, cheap hermes bags, discount hermes evelyne bags, hermes evelyne handbags as outlined by your character and elegance. Hermes Evelyne is but yet another scenery of Hermes globe. Design for Hermes Evelyne differs in the other individuals from other folks. Hermes Evelyne handbags are usual high-end, high-quality principles and various form of French conveniently. And it also blend around the epidemiological variables. The long shoulder strap makes this Hermes Evelynework effectively like a shoulder bag or cross-body bag. Also it blend in to the epidemiological variables. The Hermes Evelyne handbags retain the classic design and major excellent, the Hermes Evelyne handbags combine first-class production technology, durable with each other with all the basic elegant and exquisite. And so the Hermes Evelyne usually do not be from fashion. Discount Hermes Bags readily available!
Hermes Bags web page for comprehensive of hermes jypsiere, hermes bags, discount hermes jypsiere bags, cheap hermes jypsiere handbags. Hermes Jypsiere Handbags are typically preferred from past many years. You will discover backyard garden handbags which could be coming for some other products. Hermes Jypsiere Handbags would be the brands who have hold and enhance its value just after a though and they may be unique from other handbags. The preparing and material of Hermes Jypsiere Handbags mix the prefect and entertaining elements will most likely be satisfied with every single class. The classic and chic design makes Hermes Jypsiere Handbags are many of the most expensive bags on this planet, and Hermes Jypsiere bags are also the preferred luxury goods around the earth. Hermes Lindy come an enormous quantity of Hermes is Renowned For Its Birkin Bags, , Hermes is Renowned For Its Birkin Bags materials and colours. Hermes Wallets would be the preferred of profitable individuals,#kkep# wearing the , , Why Is Hermes Birkin Bag So Appealing? mean their status and identity, especially the men.
Hermes Bags on-line shop for substantial of hermes jypsiere, hermes bags, price reduction hermes jypsiere bags, low-priced hermes jypsiere handbags. Hermes Jypsiere Handbags are consistently in trend from earlier so a lot of a extended time. There are actually different sorts of handbags which are coming with other trend equipment. Hermes Jypsiere Handbags are one particular in the producers which have maintain and enhance its worth with time and are distinct from other handbags. The layout and supplies of Hermes Jypsiere
An easy alternative to the floating tennon might be to miter spline the corners or Miller dowel the corners after the initial glure up.
well may it be that some folks may not think it is worth the time and effort.
But to go cope and stick, you have to have an expensive set of cope and stick router bits. Fine may that be, but what happens when you cant find a bit set to match existing installation.
If you can find it, minimum 150 bucks, but chances are you can match the profile with yer router table from the plethora of router bits in yer tray!
So all you are faced with is matching the stile/-rail joint.
To do that, you make a mitre sadle that allows you to cut a perfect mitre with a few taps of a sharp chisel,, and you grind off the rest with a straight bit on the router table.
The floating tennon makes the joint, and is easy to do. .
Not a waste of time, the floating tenon jig involves a few simple WWing processes to be sure, but it saves the expense of cope and stick router bit sets/
Which somehow never seem to duplicate the profiles of the doors you have to match.
methinks yer buddy is not experienced enuf to see the persective I am sharing, nor has he likely had to pay the bills of custom made cope and stick router bitsor faced the disappointment when a 500 dollar custom ground set of cope and stick router bits just dont work. righr!!
I'd rather use what router bits I have, grind them a tad if necessary and use the floating tenon to do what i somehow end up doing.
Not a waste of time, them floating tenons, and in phyics, methinks they are stronger than cope and stick router bits sets.The leverage on the joint i s way less than cope and stick bit sets, and you can toss out any tenors where the graing ain't straight.
makes a lot of sense eh? Please tell me of the pitfalls.
Eric
