I would like to ‘dimple’ an area of one of my cabinet projects with some shallow concave ovals, maybe 1/8″ or so in size.
I’m not sure what the right tool for this would be. I am thinking some kind of knife/gouge/scoop or punch?
I have seen this occasionally on modern northwest coast Indian carvings, used on a background to give it a bit of texture.
Any suggestions on the right tool/technique would be welcomed.
Dan
Nail set?
Dan,
You could come to my woodshop, seems all my projects have dimples!!!!!!
just kidding, try some larger ball bearings. These will give a more suttle impression than others.
Ball Peen Hammer? Striking the wood with the ball end or even using a mallet to strike the peen end after placing hte ball where you like. I've never done this, it's just a thought.
I believe they use a bent carving knife.
Dan,
I just did this to a carving on a gunstock, to match some old work that I had to patch. I made a sort of stippling tool out of a 16d nail. Ground the point flat, then ground and polished it to the oval shape I wanted, to match the old work. Used a light hammer to punch the dimples into the wood, placing the end of the tool right where I wanted it ( I had carved acorns, and the stippling was around them).
Ray Pine
Thanks everyone for the quick responses.
Kovr, I also thought that bent knives were used for this, but I cannot find one small enough.
Ray, I like the idea of making a punch from a big nail. That way I can also get the slightly oval shape I am looking for.
Dan
Dan, try TANDY LEATHER. They have leather embossing punches that have oval rounded heads. buy a few sizes, (they are affordable.) Steinmetz.
Edited 12/14/2006 8:36 pm ET by Steinmetz
Can you show us a picture?
I do belive that those carvings are done with a gouge, I don't know what size. At least the old ones were done with a bent gouge.
