I am making a train/play table for young grandson. Using hard maple for frame with MDF top recessed 3/4 below top of frame. Now plannning to use 8/4 hard maple for legs. Will make it only 21 -24″ high for now but started thinking that sometime in the future it would be nice to raise it to normal table height. I could make the legs the longer length now and have the “extensions” I would want later. But the question I face is how to plan for attaching these.
Any ideas would be much appreciated. Thanks
You could "box" the short legs at a later date.
Frosty
Appreciate the suggestion. I had not thought of this approach. I will have to mull this over, try to make sure my table design makes it easy to do this down the road.
Thanks...
Bore holes in the bottom of the legs to accomodate a dowel that will span the short leg and a corresponding hole in the top of the extension. Add some kind of decorative detail (even just a chamfer) where they meet.
I had thought of this approach but had concerns on getting the dowel holes bored on a common axis. Obviously, I do not have high confidence in getting a good setup on my drill press.
Appreciate the suggestion...
To allow some margin for error, you could drill the holes as close to center as possible while the stock is rough. You then put the dowel in dry and plane or otherwise shape the leg as you please. This way the sides automatically line up and are perfect no matter how badly you might have bollixed up the drilling.
Removable legs are likely easier, but that route seems likely to limit your joinery and design choices somewhat for the apron/leg portion of the project. It is however, the simpler solution.
Make legs removable. Replace short ones with longer legs in the future.
Cadiddlehopper
Appreciate the suggestion. This may be my best option at this time. Looks like the table may get a moving van ride so removable legs might be the safest approach. Any sugggestions on good design for removalbe legs?
Thanks.....
Woodworker's Supply part nos. 892-687. 892-694, & 892-701 or 111-110 & 111-113. You'll need hanger bolts (892-771, etc.) for the first three, too. Woodcraft probably has similar items.Cadiddlehopper
