I build quite a few decorative jewelry boxes, and I like to add felt to the inside to dress-up the interior. I have been using the Presto-Felt 9×12 sheets, and it works just “OK”. These are the pre-pasted synthetic felt sheets. I ordered some 9×12 pre-pasted felt sheets from Aetna felt, but the quality with these sheets is somewhat lacking, and I am not getting a quality finish job. There must be a better way to dress-up the interior of my boxes. What do most box builders use in the interior of their boxes? One fellow-woodworker says he uses “velveteen”. What is that ? I see some spray-on felt products, but this seems like an awfully messy operation. I would appreciate any helpful advice on this subject!
Edited 7/7/2007 4:43 pm ET by Thomas00
Thomas00,
I'm sorry it's taken a while to get back to you. please be patient and I will answer you on the 23rd.
I've been getting ready for a big conference and have been preoccupied
Peter
Thomas,
Here's whats worked for me;
Using a good sharp pair of scissors and accurate measurements, you can cut the velvet to size. Use a piece of marking chalk like a tailor would to lay out the line on the back of the velvet. It takes a steady hand to cut it accurately. Be sure you don't pull or stretch it as you go or the measurement will be off.
I'll warm up some hide glue and thin it just a touch with water. Put a thin, even coat of glue on the box bottom. Holding the velvet from each end so you have a shallow U lay the velvet down into the center and lay out the sides. Lightly work any air pockets out from the center and firm it down to the surface.
You can still move it around a little to square it up. If there is any over lap on the edges, wait until the glue cures and you can lay a straight edge against the side and cut any excess with a sharp straight razor.
Be careful with the razor so you don't "pull" the velvet.
You can also lay a small book that fits nicely in the box while the glue sets.
I've never used velveteen. It's essentially a powdered product that requires almost a dusting to use.
Good luck
Peter
