I would like to make two end boards for a crib 1.25” x 32” x 40” by gluing up narrow boards. I sharpened and changed the knives in my delta 6 in jointer. I edged jointed two test boards 1.25 x 6 x 42. When I put the edges together there are small gaps between the edges on both ends. This is the first time I’ve had this problem. Is it the sharpening or my adjustments? How do I remove the gaps?
Thanks ob231
It sounds like your problem is being caused by the outfeed table being set wrong.
It is a myth that the outfeed table on a jointer is set at the height of the blades. It will be close, but the best setting for the outfeed table height is achieved through the procedure outlined below:
Assuming there are no mechanical problems, the blades are sharp, and the tables are flat and coplanar, the most likely problem is that the outfeed table isn't set at exactly the correct height. Setting the outfeed height is a simple procedure, so I'd start out trying to adjust it before trying anything else.
To set up the outfeed table height, you'll need two test boards, each about 1/2 to 2/3's as long as the overall length of the jointer, these boards should be close to perfectly flat on their wide faces with no large knots. If you primarily work with hardwoods, this adjustment will be more accurate if the test boards are also a hardwood. Never plane MDF or plywood on a jointer unless it has carbide blades, the glues in them will dull steel blades very quickly.
Start by dropping the outfeed table so that it is approximately 1/16 inch lower than the top dead center height of the knives in the cutting head. In this position, the outfeed table will definitely be too low. Also set the infeed table for a 1/16" cut.
Take a pass with each of the test boards and place them together, planed edge to planed edge. With the table too low, you should find that the planed edges are concave when placed together and each board's trailing edge will have a small snipe over the last inch or so.
Next start to raise the outfeed table by small increments, taking test cuts on both boards after each adjustment. As you bring the test boards together after each height adjustment, you should see the midpoint gap diminish and the trailing snipe disappear. Keep adjusting the outfeed table upward by small amounts until the edges mate perfectly and you'll be all set.
If you overshoot the setting, the boards will be touching in the middle and gapping at the ends of the joint. If this happens, drop the outfeed table to below the correct height and try again to get the correct setting by raising the table. Don't try to make the adjustment by lowering the table, since the setting will likely slip after the machine is used for awhile.
If this procedure doesn't solve your problem, I'd replace the knives with a freshly sharpened set, and repeat the above adjustments on the outfeed table. If you are still having problems after that, then it is likely you have some problems with the alignment of the tables with each other, which will be harder to diagnose and fix. However, being that the machine worked well before you changed the knives, it is unlikely that anything else is wrong.
John W.
