Hi all. I’m quite new to woodworking, and my garage is my workshop. I need to build a worktable. I’ve seen tons of examples, but non for what I want. Since it is such a small space, I want it to be multi-purpose so that I can assemble, work on, etc, but also as an outfeed/support table for my planer, tablesaw and mitre-saw. I’m going to make it about 2ft wide, and 4ft long (not 6). I want to make it height-adjustable. The problem is that the height adjustability needs to be continuous, meaning I can’t have “settings” like notches or bolts that are set an inch apart or something and so on because the planer, the tablesaw, the mitersaw (and other things) are all at their own heights at off increments like…35 inches, then 36 and an eighth and so on. So, I was thinking about mounting a scissor car-jack under the table-top so that I can crank the table to the heights that I want. Then I also thought of gears, or big bolts and manually lifting or something. How the top will guide up and down along the legs, etc. Part of the problem is that being new to woodworking…I’m sure I don’t know about all of what is possibly out there to use and how you more experienced WWs have tackled this kind of thing. Can you help me? Any suggestions/ideas on what to use, how you approached it, would be greatly appreciated!
We once received photos of a bench that a reader made that is raised and lowered using the scissor-jack idea you mentioned. It looked like the bed Frankenstein's moster slept on but it was pretty functional.
The commercial adjustable bench system from Noden has set positions I believe.
Matt Berger
Fine Woodworking
Matt, thanks for your reply. Yes, that Noden table is exactly the problem. It has set height increments.
In a small space you should also be thinking about mobility for your equipment. Getting them on mobile bases also gives you the opportunity to adjust the table heights of the various pieces. You may not want to make them uniform height, but you could tweek the heights so they do come out in even increments that can have corresponding heights for setting your work table.
This may be a longshot, but if you could find one of these hydraulic retrofit kits that didn't cost a fortune, it might do the trick. The company the link goes to doesn't provide a price upfront. If you Google workbench legs adjustable (hydraulic,pneumatic) you might find some others.
Edited 2/26/2009 1:53 am by forestgirl
Thanks for your reply forestgirl. Yes, I've looked around a bit at those types of solutions...which is fine. One thing that seems to strike me is that they often seem "flimsy"...you know...I feel like a nice heavy worktop will make those things top heavy...plus I fear something like a hydraulic leg as sometimes they fail and then you're "stuck" so to speak.
Yep, the look of those tables can bring that word "flimsy" to mind. The one other site I checked, though, had tables rated for 1000lb or more. Definitely for industry, and cost better thant $2/lb of capacity, LOL. Good luck with your challenge.forestgirl -- you can take the girl out of the forest, but you can't take the forest out of the girl ;-)
John,
I faced pretty much the same difficulty not long ago and decided not to bring the mountain to Mohammed as it were, but rather decided to make as many heights the same or close as opposed to making them aadjustable.
For example, I like to use sleds on my tablesaw but I didn't want to have to cut slots in the outfeed table for them. So I set the outfeed table height to 1/8" below the bottom of the mitre slots in the TS; the outfeed table floats on its own stand. If I want the outfeed table to be flush with the TS top I simply place 1/2" shims between the outfeed table and the stand.
Yes, the shims are tethered to the stand so I don't lose/resuse them. :-)
Thanks Bob, ya but, bringing the mountain to Mohammed is where all the fun is! I thought about some similar things that you are talking about. Ya, I could just make a worktable and then a sled on top and so on...but...since I'm doing it for fun what the heck.
