I have 6 in. jet jointer and need some advise on a good method getting
the blades paralell to the table and making each blade the same hieght
in relation to each other. thanks.
Hi, Grizzo,
I don't have the JET so I don't know the particulars, but I use the Magna-Set jig with the Delta 6-inch I have. The jig is basically a set of 2 bars with magnets at each end. One end sticks (magnetically) to the outfeed table and the other end holds the knife (magnetically) in place as you tighten the set screws. The jig keeps the knife parrallel and planar with the outfeed table. Works fine.
Best Regards,
David C.
I use the rocking ruler method. Lay a ruler, or other light weight straight edge, on edge on the outfeed table so that it hang over the knives when they are at the top most position. Rock the cutting head back and forth. When each end of a knife moves the ruler no more than about 1/8", you good to go. If you do the math on it, the knife edge will be about 0.001" above the level of the outfeed table. A light weight aluminum ruler works well.
I hope the following may be of interest
(1)There is an excellent article on the Fine Woodworking cd rom called SETTING THE KNIVES dated May/June 1997 pages 42 to 51
The only additional comments I would make are
(a)First zero the height of the infeed table if it has a scale
(b)Use a small piece of wood (not fingers) placed in the cutter head to rotate it when checking the height of the knives
(c) Safety is the most important consideration ALWAYS
DISCONNECT THE PLANER FROM THE POWER SOURCE BEFORE MAKING ANY ADJUSTMENTS
AFTER MAKING ANY ADJUSTMENT DO NOT DIRECTLY LOOK AT THE MACHINE WHEN YOU FIRST SWITCH IT ON (prevents eye injuries)
I would welcome comments on the above and hope my suggestions are helpful
regards Charnwood
planewood's method is similar to what makita describes to set the knives on their 16" planer. It works well.
I've used magnets, dial indicators and a few other methods along the way, and this method is an exquisitly simple method that works far better than any other I've tried.
Eric in Cowtown.
I use the rocking ruler method. Lay a ruler..Exactly.. But I use three of of them.. Ends and center...
DCarr,
My dad gave me a Magna set for Christmas. I am not sure exactly how to use it... Do you use the jack screws at all; or just tighten the nuts with the magnets holding the blades?
Dan
Hi CajunDan
I set the knives using the jig, tighten them down, then I bring up the jack screws behind the knives just snug.
So far no problems.
DavidC
Get a Magna-Set, it makes this an almost enjoyable job.
I zero the o/f table then set a piece of glass the width of the table on the o/f table and adj the blades accordingly Buckism: Will show you the the way
