Hi All
Can anyone give me information on setting up the tables on a Hammer C3 31’s joiner and planer combo? I bought a second hand machine, the tables a perfectly flat but are not alligned and the manual is not very informative, any information would be appreciated
I got in touch with Hammer: 1-800-700-0071 but the guy I talked to wasn't very knowledgeable. I'd suggest calling them yourself since you can at least describe the problem more accurately.
The last time I worked on a Hammer machine was four or five years ago and I didn't have to align the tables so I can't give you any useful advice. There are three or four different ways that tables are mounted in these machines, and they are a bit more complicated because of they are both a jointer and a planer. Without seeing the machine or being able to see the the exact cause of the problem it is hard to give advice.
You might try posting your question on the regular Knots boar, with luck you may find someone with direct experience to help you.
John White
