Advice on Chisels and Chucks for a Turning Novice
Hi All, I picked up an old craftsman 12×42(I think those are the dimensions) lathe on craigslist a few weeks ago, and have been learning how to turn. It came with a set of craftsman chisels, and I also picked up a set of old Marples Shamrock chisels for free when I bought a planer recently. I have all the basics, but the only bowl gouge I have is a 1/4 Marples. I made a decent bowl with it, but it took a lot longer than I would like. I was planning on purchasing a 3/8 bowl gouge, any advice on what to get? I went to woodcraft, and really liked the Crown brand, but I don’t have the money to spend on a $70+ chisel. My other question was about a jawed chuck for the lathe. I have a few faceplates that I can screw onto the bowl blank (or a waste block), but I can see the advantage of getting a jawed chuck. Any suggestions on something inexpensive? I looked around, and found most of them to be around $200-$300, which is a lot more than I got the lathe itself for! Any suggestions or advice would be appreciated, I don’t really know a whole lot about turning yet, but I picked up a book and have been practicing!
Drrocks,
Try the Penn States Ind. CMG3C 4 jaw. It's $99.95, which is relatively inexpensive, well-made, and works very well. You can pay a lot more, but most of the whistles and bells (Tin coating?)mean nothing. (www.pennstateind.com)
Alan Lacer (famous guy) says to get the biggest bowl gouge you can afford. Penn State has some good ones that are not too high.
Hope this helps
Steve
Thanks for the link to Penn State Industries! Tools I can afford! I am definately going to pick some chisels and pen kits, and that chuck seems like a good idea.
What do you think of this one?
http://www.pennstateind.com/store/CSC2000C.html?mybuyscid=8311032052
It's still in my price range, and comes with 3 sets of jaws. If it isn't much better than the other one, I wouldn't get it, but I guess I am not sure what to look for in a chuck.
-Chris
Welcome to turning, DrRocks! I'm a new turner also, and have found a couple of ways to save $$ on this somewhat expensive venture. Today is the last day to order the Oneway Talon chuck from Hartville Tool and get 4 excellent instructional DVD's as a bonus. They may be out of stock right now (see link below), but if you want to jump on it, do the "Contact Us" thing. Yes, it's more than your lathe cost, but good chucks are expensive -- you'll probably upgrade your lathe some day and still have a great chuck to go onto the new one.
http://www.hartvilletool.com/product/11552 Otherwise, a knock-off brand would serve you well. Research to be sure there are plenty of accessory jaws and such that you can add down the road.
Re: chisels, yes Penn State -- Benjamin's Best. Check the descriptions before ordering, make sure the length of the iron is decent (i.e., not a "mini" chisel).
http://www.pennstateind.com/store/lathe-accessories.html
I hang out at Sawmill Creek, also, for turning info -- lots of serious turners there -- and several of them use the Ellsworth gouge for bowl turning and seem to get almost all the cuts done with that one tool, which makes it an economical choice in the long-run.
Have fun!
I have a 3/8" bowl gouge and use it on smaller turnings. But my "go to" is my 1/2" bowl gouge then the 5/8" bowl gouge. Both which have a very long side grind.
