I’m considering making my own work table. I own a skilsaw 7″ circular saw that I can mount from underneath.
If I do this, my goal is to cut some wood and make some box joints with a jig.
Most videos show saw blades at 10″. It seems my 7″ can work but I would like to be sure.
I would like to use a dado set. Can all this be done?
You want to mount a skilsaw underneath a table, to make your own table saw. And then use it to make box joints. And use a dado set.
Please don't do any of those things. Please.
John_c2:
If my plan is bad I won't do it. Why did you advise against it?
I ask because there are hundreds of full time wood workers who have done this.
Is it primarily for safety reasons?
Circumventing the safety devices built into your tool IS a bad idea. If you have a router the same arrangement would be far safer as kickback would not be an issue.
Thanks for the good advice. I am persuaded to go with a router instead.
Makes more sense and I don't feel like losing a finger.
Again, thanks for this advice!
You have made the right decision - you could make a good and useful router table for the same cost and effort as a bad and dangerous table saw.
https://www.youtube.com/watch?v=G01hhn-kQnc shows you how to do box joints on the router table.
It is possible to mount a skilsaw below a table, and Triton offer a table designed for the purpose (and their saws) but you will get better results from the cheapest, nastiest purpose-built tablesaw. Even https://www.fruugo.co.nz/scheppach-hs80-table-saw-210-mm-30-mm-1200-w-230-v/p-8439010-18175731 will be better than a shop-made option and to be honest is more than enough for even quite decent sized boxes. Even so, I'd still suggest a bandsaw would be a better investment first...
On dadoes, there is a reason why the EU does not permit them. They are potentially quite dangerous. Certainly not something to be using on a machine that was not designed to use them, and does not have the power to wield them effectively.
Well a bandsaw isn't ideal for making finger joints although you could make initial cuts then chisel out the waste. I don't know of any circular saw that could handle a dado blade, thankfully. Router table is the best idea, well done.
Rob, why doesn't the EU like dado blades? They seem quite safe to me, but then I'm a daft Yankee :)
Never mind I googled EU and dado blades *shrug* I'll continue on now :)
I have a circular saw mounted underneath its own workbench. Built it about 10 years ago after a stroke for cutting sheet goods. The bench is 4' wide on each side of the blade. It was a bear to mount but I've never, repeat, never had a problem. A safety foot pedal switch makes it easy to turn on/off. The only downside is reaching under the bench for height adjustments.
Dado sets won't work on it but as I said it's only for sheet goods. And for your box joints, I agree a router's your best bet.
Mikaol
