I was given an old (or I think it’s old) Stanley No. 4 hand plane. It’s in great shape but the box is in bad shape and it’s been duct taped to hold it together. The manual is definitely of an old design. The plane says BAILEY in raised letters on it just behind the front handle.
How can I determine the age of this plane, if it’s even possible?
I ask because some have said that the “newer” Stanley planes aren’t as good as the “old” ones.
Michael
Try doing a search on Stanley Planes. Set the the search engine for updated From the beginning of time to 6 months ago this should give you a thread to a post I did a while back that revealed some great info web sites. I wish I could remember them but my brain is on drain mode at the moment.
Steve - in Northern California
Edited 7/2/2002 6:06:43 PM ET by Steve Schefer
Hi Steve,
Good to see you back.
For plane dating, try the following sites as a suggestion:
http://www-2.cs.cmu.edu/~alf/en/en.html - Section on 'lore'
http://www.supertool.com/StanleyBG/stan0.htm
Cheers,
Eddie
One again, thanks for the great info from all of you.
This will get me off and running.
Michael
Try the link below.
http://www.wwforum.com/faqs_articles/datplan.html
Scott C. Frankland
Newfoundland Wood Worker
Just a few items to check... First the plane was first offered in 1870.
Is the front knob short and squat (pre 1922) or tall (post 1922)?
On the lateral adjust lever, if the inside end is a flat 'bar' then it is pre 1888, a round end is post 1888.
I am assuming the cam lever cap has a straight 'keyhole' and no lettering, (pre 1925)
The frog adjustment screw was added in 1914
In 1905, the re-designed frog sits on a 'high' base.
Hope these 'points of dating' help.
SawdustSteve Long Island, NY
Whenever I have a question about Stanley plane I go to http://www.supertool.com/StanleyBG/stan1.htm. It is the most comprehesive Stanley plane reference I've found.
Peter
