I have decided that I should get an aircleaner for my 30′ x 10′ shop and was wondering if these are a good investment.I will probably get the JDS 750. Any experience would be appreciated.
I have the Jet version in my shop. You can really tell the difference between when they are on, and when they are off. Mine was a very wise investment in the future of my lungs.
I have the 750 and note my shop area is much cleaner (well, with respect to dust, anyway ;-) ). The auto shut-off function is useful (it keeps running for a period after you leave).
I have a JDS, a Pennstate and had a couple of Smokeaters. I think the JDS is great, it's my favorite of the ones I've had. I use the electrostatic filter which is easy to wash. The felt bags inside are also washable and you can add other types of filters as needed. I also used the charcoal filter but it has a limited life. Wide choice of fan speeds, top speed really moves some air, low speed is very quiet. Excellent quality.
I did alot of research on air cleaners several years ago, and lucked out when a "new in box" JDS unit came up at an estate auction. Lucky because from what I read, JDS was the best of the usual candidates (Jet, Delta, Grizzly, etc.). I haven't been disappointed.
Was filing away my magazines tonight and noticed there's an article on air scrubbers in the Ocbober issue of Wood Magazine (#172). Has some good information in it.
The bottom line for them:
The pictures they provide of bag filters show a big difference between those fronted with a washable filter and those fronted with a disposable (furnace-type) filter. Wow.
Edited 10/19/2006 11:55 pm by forestgirl
rompus62
I use a Grizzly but many will do.. what I would suggest however is to buy a furnace filter and put it in front of the filter on whatever you purchase..They can be very cheap say 99 cents and will help keep the other filters clean longer.. air flow will be reduced by a tiny amount but I found that if I kick mine on first and leave it on untill I leave the filter still does it's job..
