Air compressor leaking oil into tank
Hey Fellas, I have a 75 gallon air compressor and oil is leaking into the lines. I figure the piston rings are worn out. My question is> can I repair this,replace the pump,or just buy a new one which will cost around $4-$500. What is my best option?
Thanks for the advice, Lou
Repair should be possible. Check with the company which makes the compressor to see if parts are available.
Install an on line oil filter/trap. Use only compressor oil
Steinmetz.
Edited 4/2/2006 6:53 am ET by Steinmetz
