I am setting up my workshop, looking for ideas, recommendations for those air filtration systems (looks like a box mounted to the ceiling or wall up by the ceiling) also looking for dust collecting system that doesn’t make a rackett when it’s running. Any help would be much appreciated..Thank you
Hi Deacon,
I've used the box-mounted setups and don't think they're all that good....they tend to pull the dust up (past your nose and mouth) and, frankly, don't filter all that well. I read somewhere that OSHA won't approve these filters because they're just not any good for worker safety....
I'm a fan of the combination cyclone/dust collectors with filters..not bags...those are
dust-distributors" IMHO. I put that setup behind an insulated sliding door and switch on/off with a remote switch...works reasonably well.
Good luck.
lp
Larry,
Are you referring to the spun bond polyester type canister filter?
I'm thinking about perhaps getting the G0548 unit from Grizzly, but notice that it's rather expensive to replace those filters ($160). Wonder how many hours you get on one of those, before you have to replace?
Probably a stupid question, but what's the difference between circulation air through a box mounted filter compared to just leaving the blast gates open on your machines to circulate the air through your dust collector?
The other alternative is perhaps a home made box, with filter, connected to your dust collector?
Willie
First, all your dust collecting budget should be spent on dust collection at the source of the dust. That said, here is some info you might find helpful about air cleaners.
The two most important criteria for an air cleaner are the CFM and the filters. You want a CFM factor that will clean the size of your shop and a filter that removes the particle size that you are concerned about.
To determine the size or required air flow, use this formula: Volume of your shop (Length x width x Height) times Number of air changes per hour (typically 6 - 8) divided by 60. This will give you an answer in Cubic Feet per Minute which is how air cleaners are measured. MOST AIR CLEANER MANUFACTURERS RATE THE CFM OF THE FAN ONLY, but there are losses due to the filters. If you are building your own or if the air cleaner you are purchasing rates only the fan, figure you will lose about 25 - 40% for filtering losses.
As important as the air cleaner size is how and where you mount it. Try to mount at about 8-10 feet above the floor (no lower than 6'or 2/3 of the floor to ceiling distance if less than 8' ceiling). Mount along the longest wall so the intake is approximately 1/3 the distance from the shorter wall. Mount no further than 4-6 inches from the wall.
The exhaust is the largest determiner of the circulation pattern. You are trying to encourage circulation parallel to the floor/ceiling so ceiling mounting is not recommended. Use a smoke stick (or a cigar) to observe and maximize circulation. Use a secondary fan to direct air to the intake if necessary. Also, consider that a standard 24" floor fan moves a lot of air and, in some shops, just positioning it in a doorway with a window or other door open can accomplish as much or more than an air cleaner. It's all in the circulation patterns.
The exhaust is the clean air so that is where you want to position yourself. Do not place the air cleaner over the a dust producer. That will guarantee that the operator will be in direct line between the dust producer and the air cleaner. The operator wants to be in the clean air stream. If the dust has to pass your nose to get to the air cleaner, you get no benefits. If you have an odd shaped shop, two smaller units may be better than one large one.
DO NOT RELY ON A AIR CLEANER TO ACT AS A DUST COLLECTOR. The purpose of and air cleaner is to keep airborne dust in suspension and reduce airborne dust as quickly as possible AFTER THE DUST PRODUCER HAS BEEN TURNED OFF.
Finally, if you are looking for health benefits, you will not find any air cleaner manufacturer that makes health claims because there are no health benefits. CATCHING DUST AT IT'S SOURCE IS THE BEST LONG TERM GOAL. Rick Peters', author of "Controlling Dust in the Workshop", makes the point that spending your money getting the dust at its source is a better investment than trying to capture it after it is already airborne. If the dust is in the air, it's going to be in your nose and lungs too. Robert Witter of Oneida Air Systems has noted that "overhead cleaners can only lower ambient dust levels AFTER THE SOURCE OF EMISSIONS IS SHUT DOWN, and they take several hours to do this. This is why they are not used in industry." The absolute best answer, if health is the primary concern, is to use a NIOSH approved respirator. The dust cleaner will help keep your shop cleaner but have minimal or no health benefits. OSHA takes this position too. They measure the number of particles per a volume and most air cleaners will not satisfy their specs.
Howie,
Good post!
Any ideas, or information about how to collect dust from a wood lathe?
Willie
Nope, sorry, I'm not a lathe guy.Howie.........
Thank you very much Howie, You gave me a great deal of insight, I appreciate that very much. Thanks again for your help and interest in my question.
Deacon
