what style air hose coupler is leak proof? I’ve got one set, it looks just like the leaky ones but has a longer shank that I’m guessing goes into a rubber gasket sealing it. I can’t find any identification on it… what do I look for to buy more?
I don't know why you should be having problems with your connectors, unless they are really el cheapos.
I buy Milton quick-connects -- but only because that is the brand sold by my local tool outlet. Some of them must be 10 years old, and they still don't leak -- even though they're subject to the rigors of job site abuse.
I assume you know there are about five different styles of fittings for air equipment. If you specifiy "universal" that will cover the 3 most common fittings.
"I tend to live in the past because most of my life is there."
-- Herb Caen (1916-1997)
Take your existing connection with you to a pneumatic supplier. There are quite a few different sizes available and it's always nice to keep everything matching.
Grizzly sells a reasonably priced coupler that seems to be just a good as the more expensive ones I typically buy for my company. http://www.mcmaster.com and many others sell them but for the hobby guy the Grizzlies are perfect. I'm buying them for the shop as well.
I use the quick connect ones from harbor freight. They are the automotive tool style. I have had good luck. The critical part is to be sure to use Teflon tape on the hose threads. I leave a blower attachment on and pressure on the line, and the unit does not leak. I do get the brass ones, not the aluminum ones. What I would really like is an auto retracting reel, but I won't fork over the money yet. So I'll just keep winding it up by hand. Some conveniences I can wait on.
If you want a hose reel, look at Harbor Fright(sp?- just kidding). They have a 3/8" I.D. hose/reel for $40 on sale, pretty often. It seems to be exactly like the ones I bought for a couple of places where I worked and is $125 less. I just need to beef up the stretchers in my garage before I mount mine.
as it turned out it was one faulty coupler, into the trash barrel and all is well now. thanks all.
If you work on a concrete floor, be careful not to drop the male end will get a little dinged when thy hit the floor, making it hard for the rubber to make a good seal.
Devilbiss, high flow connectors.
Last forever, much bigger inside diameter and internals are designed for least resistance to air flow.
They cost a bit more, but the costs are quickly recovered in compressed air efficiency, which appears on your electrical utility bill.
