I’ve been using melted canning wax to coat the ends of cut logs, but this cedar we’re cutting up this weekend will be waaaay too big for that. Thought about using Anchoseal but (a) it’s really expensive and (b) I’m not sure I can get it locally (haven’t checked yet) and (c) it only needs to last for a month or so, so shorter-lived alternative would be OK.
So……suggestions????
If you are not going into a kiln with the wood, you can probably get by with just using a white primer. That is what I do for my turning logs. The chainsawn end-grain leaves a pretty rough surface that will hold a pretty heavy coat.
I heard some Folks use Latex Paint.
Hilmar
Jaime,
The objective of sealing the end of the log/board is to prevent watervapor from escaping. It will escape much faster from end wood than surface wood resulting in faster shrinkage of the wood in the end of the log. This leads to checking and splitting. You want to force the watervapor to escape through the surface of the log in the whole log.
So, what you have been doing is just fine. Anchorseal is just a water emulsion of a wax that can be applied heavily. There is nothing short of encapsulation in plastic that prevents water vapor transmission better than a thick coating of wax. All normal finishes provide rather short term (days rather than weeks) barriers to watervapor.
One thing you could try is to use multiple coats of a polyurethane finish. Something on the order of ten coats might give you a pretty good barrier for a month. Of course, that much poly may cost as much as a container of Anchorseal.
"So, what you have been doing is just fine." Well, yeah, on smaller (and many fewer) pieces. Have to keep heating up the wax though, and I suspect wax would get reallllll expensive. The Anchoseal's looking better and better. I probably have some old buckets of oil-based paint around too......forestgirl -- you can take the girl out of the forest, but you can't take the forest out of the girl ;-)
Oil based paints typically won't work with green(ish) logs because it won't stick too well to wet wood. Latex paint is porous by nature so doesn't seal too well. I've painted anchorseal on green, wet wood with no problems. No good if it's raining though - it'll get washed off.
"No good if it's raining though - it'll get washed off." Boy, you're just no help at all! ROFL!! this cedar has been dead for over a year. I don't know what to expect when we get inside. It was trying to grow a few new needles up toward the top of its 75' trunks (of which it has 5 or 6, can't remember).
Hubby is now thinking about ordering the new chain saw on-line, so I may have a week respite to order the Anchoseal. Talking him into spending $50 or so for a "facial peel" for the logs might be a trick. <g> Will keep you posted.forestgirl -- you can take the girl out of the forest, but you can't take the forest out of the girl ;-)
The chain saw carving guy out by Ocean Shores recommends log sealer that is sold through your local Ace store. Might want to try that.
As a a side note, I haven't heard back from you on the stove. So, what was the out come? I hope it wasn't "bad news..."
Hey Jamie,
Woodcraft sells a product, similar to Anchor Seal, by the gallon. I used it on the black locust, and cherry that Dennis gave me, and it seems to work well enough.
Tom
Anchorseal is only expensive if you buy it from the designer woodworking stores. I've been using it for about 10 years and get it directly from UC Coatings. The last time I bought some, it was about $50 for 5 gallons - delivered. It works better than latex paint and is cheaper. I'm pretty sure they'll ship 1 gallon pots too. Give 'em a call.
https://www.uccoatings.com/prod_anchorseal.php
You might find some pertinent information here.http://www.woodweb.com/cgi-bin/search/search.cgiGood luckRon
Thanks for the link, Terry, that helps!forestgirl -- you can take the girl out of the forest, but you can't take the forest out of the girl ;-)
I have been using Green Wood Sealer from Woodcraft. I can use it in cold weather which it seems to be where I live most of the time. So far I have had good luck. It works much better than latex paint and is just about the same consistancy.
http://www.superwoodworks.com
Thanks, Garry, I'll check it out!forestgirl -- you can take the girl out of the forest, but you can't take the forest out of the girl ;-)
F-G
being basically cheap and resourceful, I've used (1) broken wax toilet rings and (2) leftover-about-to-throw-out shellac, succesfully.
hi,
cedar isn't prone to checking, in fact, it's probably as good in that regard as anything I can think of. Just use any old paint you have left over. Shellac is as good as anything else, and cheaper than anchorseal.Gotta go, crying baby.
