I have four cabinet doors to build, to match the existing cabinets in a kitchen, due to the owners replacing appliances with different size units. The Amerock hinges are readily available (I don’t have the number right here, they are in the shop), but they install in a T-slot in both the door and face frame, with a clamping mechanism that allows adjustment. And, the two T-slots are different sizes. Imagine the shank of the T at 3/8″d and 7/16″d and the slots at 1 1/8″d and 1 3/8″d. I realize I could put together a jig or two to cut these with some standard bits, and that a special cutter will probably not be cheap. But am wondering if anybody has any hot tips. My other problem is matching a European style finger pull edge, just different enough from the one I have to be noticeable, and catalog descriptions have little details on the actual shape. My local tool dealer carries Whiteside, which I haven’t checked yet, but most catalogs don’t show a full size profile of the bit. Surely, somebody here can help me save some time on this job, of just two small cabinets?
The hinges you describe sound like what are called Double De mountable , also available in single de mountable where the door only gets a slot for the hinges and the half wrap screws to the inside edge of the face frame.
There is a special machine for the face and door slotting also there is the router bit only that slots the door. I have the special hinge slot bit and would use it with the single demountable .
For you the next best thing is to use Amerock style half wrap hinges ,that screw to the back of the door and edge of the face .
hope this helps
dusty
Dusty,Thanks. I had seen the wrap around hinge in a catalog, and was reasonably certain it was visually the same, and will probably use it for two of the doors. Two of the doors are at about eye level, so I will re-use the existing hinges, for an exact match, as per Dave's suggestion. The other two doors are at about shin level, to a minor difference in appearance will not be a problem. I live in an area where Euro (Blum) hinges just became available in the past year. When I made the switch from wrap arounds to Blum, I had to mail order, and keep a fair amount of stuff in the shop, because of the huge variety of plate and hinge combinations, to deal with jobs like this one.Now I just need to deal with the fingerpull profile. The usual PITA of matching a ten year aged color is actually going to be the easy part of this job.Fred
Do a couple of mockups if you try to use cup hinges on a profiled door. It can be annoying when the cup hole breaks thru the profile.No, you MAY NOT ask how I know that!!! - lol
Edited 2/28/2009 1:41 pm by Dave45
I resemble that remark !
You too, huh?When I hear the phrase "Been there, done that, got the T-shirt", I always add - "And you oughta see my T-shirt collection!!" - lol
Do your hinges look like this (first pic)?
I ran into these on '05 while making new cabinets to go into an existing kitchen. When I found out about the special tool needed to make the "T" slot, I removed the piece that goes into the slot, replaced the machine screw with a wood screw, and mounted the hinges (pic 2). It worked like a charm
yup , Precisely !
Dave, That is the hinge, and I think I will use your solution. Will just be extra careful to get the fit just right, since I'll lose the adjustability. At my first glance at the hinges, I actually thought the screws were the mounting screws. Thanks, sometimes the simple, obvious solution totally escapes me.Fred
No problem. Glad I could help. In the interest of full disclosure, however, I gotta tell you that it took me a couple of days to figure out that solution. - lol
