Has anyone tried fuming Ipe with ammonia? Looking to get something less red out of it.
Never even considered it. I've only used it outdoors.
Ammonia reacts chemically with the tannins in wood. Oak and Walnut have a high tannin content and ammonia will darken them easily. I don't know if Ipe has much tannin. I suggest you buy a bottle of Janitorial Ammonia at Ace Hardware and experiment. Janitorial Ammonia is a 10% Ammonia which will darken tannins over time but won't do you harm. Take a small piece of Ipe and some Ammonia in a glass or plastic container and put both under an upside down sealed up box or plastic tent. Let it sit for a couple of days and see what result you get.
I have anhydrous ammonia and all of what is needed for safety, I've fumed many times. I'm just looking for others' experience as to whether Ipe is worth the effort.
Try a small piece and see what happens.
Yes, thanks, I know. If there is anyone out there that has tried this in the past please chime in and let me know what you've found.
I know Ipe will fume plastics. Had a bunch in my wife's car trunk years ago and it turned a case of water bottles and some other things yellow. Such weird stuff.
Just a followup on this thread. I decided against the ammonia fume because I tested with heat first. The photo shows Ipe before and after 4 hours at 400 degrees. I wrapped the wood airtight in heavy foil. It darkened to almost jet black.
I had similar results with Cherry.
Now I want to try cooking some wood.
Nice follow up. What a nice look without chemicals.
Or, you could try vinegar.
Have you tried vinegar on Ipe? What were your results like?
_MJ_ That sure looks like a fretboard in #7... but what's the instrument?
@ Bluemo, It's a soprano ukulele. I am at the scary stage of taking it to the router table to make rabbets for the bindings.
Nice! Best of luck with the bindings and the completion of this project. Real craftsmanship is evident.
It sounds like you've done this before, any tips? I am using stewmac plastic bindings, 2 layers B&W. This is my first attempt. I have the stewmac binding glue. With so much time into the body I'm a bit skittish about it.
The only bindings I have done was on the straight neck of a lap-steel guitar, using products from Stewmac. So that was pretty simple in comparison to what you have. I can understand your hesitancy in going forward. No doubt you have checked the online videos for guitar bindings. I wish I had some masterful first-hand experience to offer - but I'm strictly amateur myself. So take some deep breaths, stay relaxed... and don't use too much glue.
Here is a research paper on ammonia fuming wood, with references to several others. It mentions the differences in color fastness ammonia compared to heating wood, too.
https://www.ncsu.edu/bioresources/BioRes_07/BioRes_07_3_3767_Miklecic_SJ_Wood_Color_Change_NH3_Fuming_2762.pdf
Scholarly articles on tannic acids in wood:
https://scholar.google.fr/scholar?q=tree+species+with+tannic+acid&hl=en&as_sdt=0&as_vis=1&oi=scholart&sa=X&ved=0ahUKEwi55aaKspTYAhVkAcAKHb26AWAQgQMILDAA
Short video about two slightly eccentric but charming luthiers. Short sequence on binding. Hope the link still works....
https://norcalpublicmedia.org/media/com_joommedia/files/76/70/22/5c64b53fe3c79d4c420b38ef01199e1a.mp4
