What is the correct angle to sharpen jointer knives?
Why do you want to change the angle? Are you working with difficult grained wood?
I don't, I nicked the knives, need to repair and wanted to get the angle right.
I think you're going to have to use an angle guage or protractor for this. I'm not sure they all use the same angle. You could also use a bevel guage and a very flat surface for this. Otherwise, good lighting and a keen eye will be needed. What are you using as a guide?
Is there a problem with reading the angle from the knife itself? Sorry if I (we) are being obtuse, but your reference is in the knife itself. Take a look at the Veritas Jointer Blade honing guide, for example. You simply turn the "elevating screw" until the knife's bevel lies flat on the sandpaper, and off you go.
In an early attempt to sharpen I believe I have changed the angle to an undesirable/incorrect one and being an engineer, I can't stand it being wrong :-)
Ahhhhh, OK, now I get it. Looks like you got your answer up above.forestgirl -- you can take the girl out of the forest, but you can't take the forest out of the girl ;-)
Thanks to our sponsor, I dug out my copy of Taunton's Complete Illustrated Guide to sharpening, By Thomas Lie-Nielsen. He states that normal factory bevel is in the 35-40 degree range. Or if you change the bevel to 30 deg. which he says is common, also stateing you may want to add a 10 to 20 deg back bevel which is 1/32 to 1/16 wide.Work Safe, Count to 10 when your done for the day !!
Bruce S. Counter Sales, Tech Rep. http://WWW.EAGLEAMERICA.COM
40° is the norm.
mike
My Makita 2020 jointer came with new blades sharpened to 40 degrees. My Delta RC-33 thickness planner came with new blades sharpened to 35 degrees but replacement blades by Freud came sharpened to 40 degrees and they work fine. As I now sharpen my own blades with a Makita 98202, I rough sharpen the blades to slightly less that 40 degrees and then sharpen just the edge at 40 degrees. This makes it easier to get a sharp straight edge with an effective cutting angle of 40 degrees.
I use William Ng's (http://www.wnwoodworkingschool.com) planer blade sharpening jig, which he describes and I built from his video.
Fast and Easy Way to Sharpen Jointer and Planer Knives
https://youtu.be/pUoEPgcqUFc
