I am installing 6″ crown on top of cabinets working right to left.
I’ve come to an inside corner that makes a short jog- 3″, and comes to a corner cabinet that obviously has a 22 1/2 degree face, and am having a hard time figuring the angle for the jog.
I have a 12″ compound sliding miter saw, and am cutting the crown laying flat.
thank you
Nuge
Edited 7/18/2007 9:57 am ET by woodbeenuge
Hi Nuge,
I don't quite follow but it might be easier to visualize if you cut your material upside down and angled against the fence like it will sit on the cabinet. Then it should be a ( as it lays on the saw like above ) a 45 degree cut on your left with a 11 1/4 degree cut on your right.
Paul
I've done it that way before but because of the size of the crown,
and the fact that it has a foot on it, I took the sliding compound from my shop to do the job.
Now that I'm at a place that is not a 90 degree because the corner cabinet is not a right angle I'm stuck
Think of a pantry in a corner. it goes across the 90 , but stands 3"proud, and should be a 22 1/2 like one face of an octagonal
This crown is made by Thomasville, and has what I call a foot to attach to the top of the cabinets not to the face.
Edited 7/18/2007 6:57 pm ET by woodbeenuge
Edited 7/18/2007 7:01 pm ET by woodbeenuge
Edited 7/18/2007 7:06 pm ET by woodbeenuge
In other words the upper cabinets on either side of the corner one are slightly deeper?
Paul
just re-read your post . The corner unit is proud of the cabinets on either side. I see your problem. Did you try cutting some experimental pieces? Could you fabricate corner blocks that the crown could die into? Without mocking something up I 'm not sure what's going to happen with crown that wide.
Maybe someone else can chime in here.
Edited 7/18/2007 7:22 pm ET by colebearanimals
If it is an inside corner coping it is the easiest way.
Pardon my spelling,
I bet you're right about the coping. That makes sense.
I still don't know about the angles when I'm cutting on other than a 90 deg. The set angles and tilts may not apply. Because of the foot, I had to raise the crown up from the table with a couple layers of 3/4 ply.
I've allready done 75% of the job when I ran into this dilema, it was getting late, and I figured my subscription to F.W.W. online would pay off here!
I did do some test pieces but the harder I tried the behinder I got!
make a mock up crown mold on your table saw that you can cut standing up on your miter saw. the lay flat and match the angles. that is how I do it.
