Another thread here spoke about a dust control problem with their jointer. I have a similar problem but it doesnt seem to be for the same reason.
When I turn on my jointer (Delta X5 Model 37-275X 6″ Jointer) it continuously throws wood chips up onto the jointer bed (whether Im running wood through it or not). When I hook my shop vac up to it(I dont have DC yet), it doesn’t seem to help too much either.
I’ve used jointers before, but this one seems to be worse than the others. Does anyone out there have experience with this model? Is there something wrong with my jointer or is it a design defect?
Thanks for the info.
Frank,
Sounds like the chute is clogged. Sometimes the shavings will hang up just under the bed of the machine, waay up at the top of the chute. (The chute appears to be clear, but it isn't.) Your shop vac may not have enough gumption, or too small a hose, to do the job.
Ray Pine
You probably have shavings tightly packed in under the table clogging the dust chute, they'll need to be dug out. The shavings got jammed in probably because the shop vac couldn't remove them fast enough. Unless you take very light passes you will need a larger dust collector to properly handle the shavings produced by a jointer.
I concur with the other postings, you have a clog somewhere. Jointers can produce a LOT of shavings and will quickly overwhelm a shop vac. Time for DC!
Best,
John
Yes it will take a bit of effort to really clean it out. Just make sure you are unplugged. Also, some compressed air may not be a bad idea either. You don't want your hand near the blades.BTW, in another thread, I mentioned Frank Klausz's sugestion on having 1/4" of travel when setting the blades, and John White suggested that was too much. Well, I spent some time trying out various configurations (my Felder jointer is easy to adjust), and John was right. My blades just about brush the underside of gthe test piece, moving it less than 1/16", actually not moving at all, just hearing the nick, and performance is much better.One small item: use a laundry marker to note the nubmers of each blade and slot; that way you always know what you worked on.Thanks John.
Man O Man I hate when the jointer clogs. My 30" Oliver 166 cloged while taking a 1/4" cut on a 28" wide walnut slab. Had to use a sewer snake to clean it out.DJK
Hard to feel too bad for a guy with a 30" joiner and 28" wide walnut.
But hey, its all relative.
Doug
Ah, Evil J, I am having a quiet chuckle here: you would know about making some huge chippings with a jointer....(;)Philip Marcou
Dear Philip,
So nice to be remembered! Yes, I DO know a bit about making huge chips with my jointer, shall we re-open the discussion? Assuming that no one wants to......... I can attest to the fact that even when making "maximum" cuts, a 3 HP Oneida cyclone with correctly sized pipe can easily handle the "chunks" even with 75' of pipe.Best,(Evil) John
Ditto to everyone above. The jointer was the only tool that I could collect from easily with a large shop vac. Go in and clean it out, you should be fine.
Hmm,So you all think this is a clog? Interestingly enough this jointer did that from the moment I got it (new)! And I assembled it myself.
Dear Frank,
Perhaps a shipping block is the culprit then. They stick those blocks of styrofoam all over those machines, perhaps they buried one on you. Maybe just a piece of tape or similar as well. Are you getting anything into the shop vac?Best,John
Big Frank:
Clean it out as suggested. Blast it with compressed air. Make certain of its cleanliness. If possible, remove the panel with the dust chute on it. Place a box below the chute to catch shavings. Run the jointer to see what happens. The jointer may still clog when planing a wide board. If it does, your only hope is to attach a dust collector with mucho suction. Forget using a shop vacuum. Sometimes we have to live with problems, but it helps just to know their magnitude and causes.Cadiddlehopper
I have the same model jointer and mine has also done it from day one. You don't have to shave very much at all off a 3-6 inch board to clog it up.
Mine seems to clog about 18" up the chute from the bottom. I unblock it with my hand and blow the rest out from the top with compressed air. I'm hoping that when I get a dust collector on it I won't have this problem.
-doug
Thanks for the comments all!I'll give that a try and see if I get better results.
