I’ve just moved into a 1926 spanish fixer. I recently got an antique mahogany sideboard that’s missing a marble top. I am planning on using it as a vanity in my bathroom. Does anyone have any suggestion on what type of finish I may apply to it to protect it from water and steam?
THANKS!!
Well almost no finish will render your piece bulletproof to mositure changes, and I'd say at least make the attempt during use not to get things wet and let them stay that way. Finishes that resist water fairly well: nitrocellulose lacquer is ok, a step up from that would be your Alkyd varnishes, then I'd say your conversion varnish / CAB or precat lacquers, and the high end phenolic resin varnishes probably the best at water resistance. Behlen's "Rock Hard" table top varnish is a phenolic that I like fairly well. Brushes much better when cut down about 1 to 3 with naptha, and rubs out very well if you're looking to change the sheen. That being said, find out ahead of time what's on it, make sure what's going over it is compatible, and clean the surface well. This is probably a good opportunity for a sealer / tie coat of shellac (dewaxed) if you have any doubts.
Thanks so much for your answer and suggestions. I guess I have some homework to do. I recently bought "Great wood finishes" and "Hand applied finishes". I need to read up on it to be able to understand everything you suggested.
novice
Novice,
Epoxy will seal the wood so that moisture would not be a problem. However you must completely encapsulate the wood with the epoxy for it to work. This means making sure that every tiny bit of wood is coated, inside, outside, upside down. Any time you break the epoxy seal, whether by drilling for screws for a towel rack or a deep scratch, you will have to re-seal that spot with more epoxy.
I'm a huge fan of epoxy. Your plans would be an excellent application for it. Go to the library and look at The Gougeon Brothers on Boat Construction; it's a great primer on the use of epoxy on wood.
Alan
Alan,
THANKS for your reply and your suggestions. I'll go to the library and see if I can find the book you mentioned.
novice
And, this company publishes a free newletter which you can subscribe to on its web site, and has much information. They do the West System epoxy, which is a great product.
