Anybody ever try this Dust Coll from Jet
I’m looking for a dust collector for my 8″ Jointer and 15″ planer. I don’t intend to use it for other tools and only use the planer and jointer one at a time. I usually plane fairly wide boards and the planer produces large volumes of shavings. Does this thing work? Any advice?
http://www.wmhtoolgroup.com/shop/index.cfm?navPage=4&iid=11785
Don't know about that one, but I use a Jet 1100, like this:
http://www.wmhtoolgroup.com/Shop/index.cfm?navPage=4&iid=6053300
For me, this Jet has been reliable and durable.
So even though the configuration of the model you asked about is different, the guts are probably very similar.
John Wooden 1910-
I don't know what the regulations are in your area, but in Ann Arbor I would not be allowed to put out the can with the sawdust and chips if they were not sealed in a bag. I was watching one day when I put something like that out as the collector dumped the can. I thought he would choke to deathas the wind caught the dust. I really felt guilty. Then I learned of the local regulations and saw why.
I think that collector comes with bags that can line the trash can. You're right about not leaving loose sawdust out in the trash collection!forestgirl -- you can take the girl out of the forest, but you can't take the forest out of the girl ;-)
I've had one for nearly three years. Use it in the shop for lunchbox planer, saw, and Performax sander. I have a 3hp planer also which I use outside. It handles most any volume of shavings I produce. I use a max 10' 4" DC hose, one machine at a time.
Got frustrated with the filter filling up w/ dust/shavings and added a second trash can ( I use the Brute) with cyclone lid and that has made it a better performer. Now only have to empty the can w/ DC motor just three-four times a yr. Just recently set up a pipe to vent exhaust directly outside and eliminated the filter altogether. Where I am this will work about 9 months of the year.
Another modification which is needed: I put an eye bolt in the top of the motor and rigged a rope and pulley in a ceiling beam (mine is outside under shed) so I can hoist the motor assembly up and suspend it while changing the bag in the can. The motor assembly is HEAVY and a PITA to lift off without some help.
I've also started thinking of making some sort of Tee off the exhaust side so filter could be mounted pointed up and a bag/bin of some sort could be mounted under it. My theory is that loose chips/dust that are pushed up into the filter would fall when the unit was turned off (like the larger DC's are built).
Also just had motor bearings replaced cause I was getting some intermittent squeals.
Bottom line: Unit is adequate if you provide some solution to the filter loading up.
Diz,
Can you add some more info about how you made the modifications to add the second can and cyclone lid? Did you buy the lid or make it?
I picked up a jet cyclone lid from my local dealer. There are several on the market: LV, Highland, etc. Can't comment on one vs the other. Connected the two with about a 3' 4" dia DC hose. I've got the main collector on shop built roller base so I can move it outside when needed.
I use bag liners in both drums, but you have to devise a way to keep the plastic from being sucked into the outlets.
My first barrel was one of those paper drums used to ship link chain - it lasted about 8 seconds after I turned unit on the first time. Sucked sides in till it looked like a big brown prune. That's when I switched to the plastic - I recommend getting the commercial grade if you're not going to use metal.
"Sucked sides in till it looked like a big brown prune." Thanks for my first good laugh of the day!forestgirl -- you can take the girl out of the forest, but you can't take the forest out of the girl ;-)
<and suspend it while changing the bag in the can>Diz,How does the bag in the can not get sucked up into the DC? I bought one of these a while ago for my RAS and router table, and based on my first experience, I would think that would be the case. The first can I had was light duty plastic, and the DC sucked the sides almost together. I'd like to be able to just lift out a bag and chuck it when full, but figured I'd end up picking plastic out of the impeller instead. Great idea on the eye bolt, rope and pulley system -- you may have postponed my next back surgery.
I was hoping nobody would ask, but here it is. You familiar with what looks like corrogated plastic which is used for signs? During political campaigns you see a lot of 4X8's printed with smiling faces - and, what can I say -I believe in recycling.
This stuff will roll in one direction and spring back - just cut it to height and then length of circumference of inside of can. Insert bag in can, roll the plastic sheet stock into a tube smaller than the can, put in bag and turn it loose - it will flatten the bag against the can sides. When you're ready to empty, just slide the plastic liner out of can. Since most cans taper at bottom, I cut vertical slits in bottom edge of plastic about 4" apart about 6 to 10" long. This lets the plastic liner conform to the taper of the can.
<During political campaigns you see a lot of 4X8's printed with smiling faces>Nothing like a smiling face on a campaign sign. Elegant solution, thanks.
Quick,
I have had this model Jet for several years and am satisfied with it. I bought it because of its compact design (meaning low profile, no tall dust bag) so I was able to place it centrally so it serves my table saw, bandsaw, jointer, planer and lathe. It provides plenty of suction, though I'm sure not as much as a 2hp would. One drawback, as Diz pointed out, was that it loses suction when the cannister filter gets clogged, so the filter needs to be cleaned fairly often if you are using machines that produce dust rather than chips. And I agree with his remark about the motor assembly being heavy and awkward when removing it from the trash can. Other than that I am satisfied with it. Gary
I have the Delta version. 1HP, 750cfm. I’m pretty happy with it. I use it for my table saw, band saw and jointer. The lid is heavy and awkward to remove. The unit is only slightly more compact then a regular bag over bag single stage unit.
I found that using it on a 55 gallon drum works best. When I placed the unit on a
33 gallon trash can, I had to much dust/chips exhaust out & almost emptied the trash can. When I placed it on a 44 gallon drum it got better and 55 gallon worked out the best with only the fine stuff exhausting out.
My .02 – I had look at that unit before purchasing my Delta and last time I checked these were selling around $350. I think for $350 you can pick up a single stage unit with higher cfm’s that may handle your 15” planer better. If you can get a good deal on one then it’s not a bad dust collector. I picked up my Delta on E-bay for $125. The unit is 10 years old, but was brand new in the original box.
Yes, I have had one of these units for several years. I doubt if it could keep up with your planer. Also I don't like its propensity for leaks both where it sits on the dust receptacle and at the connection between the blower and the filter. I've had a Jet 2HP canister unit for the past year which I find preferable in every way. You may want to check the filtration rating of cannisters from various brands as they do vary.
