Was considering purchase of either a Delta or Jet Mortising machine. Both are about dead even in price, hp, capacity, and appear to come with same accessories. Any experience or opinions would be appreciated.
In advance, many thanks.
Phil
Phil
I have the Jet mortising machine and it is nearly identical to the Delta. The mortising bits that come with the machine are not very good. A good set of knives improves the machines performance greatly. Also, these machines suffer from a poor work peace hold down. Its ok for soft wood, but I find that when I am working with hard wood the work piece has a tendency to lift off the table as the morticing bit is drawn out. I some times clamp the workpiece in place, however this really slows the mortising process down. I would like to see some ideas on a homemade clamp system.
As far as which one to get, it’s a coin toss in my opinion. I think when I bought the Jet, it was $20 or $30 cheaper at Woodworker’s Warehouse. I did look at both and like I said before, they seamed almost identical.
Jamie
*Jamie--many thanks for the input, I have a Jet milling Machine which is OK for the money paid. I'll probably go the elta Mortsing Machine beacuse I can get it around the corner. Greatly appreciate your opinon.Phil
*I also am looking for a good mortising machine and wonder if anyone has experience with a General unit? It looked more solid in the store, next to the Jet and Delta, although it was $75 more expensive. Has Fine Woodworking done any product reviews on this? I cannot find one. Thanks.
*FWW last ran a review of the benchtop units in June 1996 (No. 118). We did not, however, review the General, which I don't think was available then. My personal experience with these machines is that the 1/2 hp models are OK for mortises up to 5/16-in. For machining a bunch of 3/8-in. mortises, well, let's just say the task will try one's patience. Main issues are power, quality of the hold downs and bits. But the Multico is a cut above the others in terms of how the hold down was designed and the quality of their bits.
*ok, bite yer tongues. I decided to buy my bench top from Harbor Freight. After looking at the other brands, I realized that they are all made by maybe 2 to 4 different companys and what the heck, the only real difference is that I may have to get my bits elsewhere. Still using the bits that came with it and while it isnt as convenient as a floor model, neither are the others. Not bad for under $130.
*I bought the Jet, which is slightly more powerful, amp wise, than the Delta. It's a great machine. Take my advice, spring for the Clico bits available from Garrett Wade if you want to do through mortises.They cut a very clean square opening. The cheap Taiwanese bits are really only good enough for blind mortises, as the slightly ragged edges will be concealed by the tenon shoulders.
*In a recent project, I needed to cut more than 1500 mortises in western red cedar. I first bought the Fisch mortiser, but returned it after a few weeks--the bits kept stalling after getting clogged. I replaced it with a Jet mortiser, and I'm very happy with it. A thousand mortises in cedar, and a bunch in mahogany, cherry, and hard maple, and I haven't had a bit stall once. Although I've heard that the Clico bits are superior, I decided to just sharpen the bits that come with the machine. Flattening the outer surfaces of the chisels on a sharpening stone does wonders. You can use a conical stone to sharpen the bevels. The only real problem with the machine is the hold-down--which is almost useless.
*Ditto on the hold-down, which is inadequate on every machine I've seen, except for the Multico. I saw a good jig design in FWW recently with an aluminum plate replacement table and a De-Sta-Co in line clampto press the work against the fence. I suppose you could rig up a similar hold-down device. I find I need to clamp the work down and tight to the table and fence for every cut if I want a really clean mortise. I have a jig in progress in my head that would satisfy all these concerns, now all I have to do is actually build it! One more note DON'T buy any machine that runs at 3450 RPM, they trash the bits and burn the wood. Stick with a 1750 RPM unit.
