Hi,
Before applying a stain is it ok to fill the knots and minor imperfections with wood putty? Can you brush on shellac over wood putty? When applying a dark stain to pine is it best to apply a thin coat of shellac first? In the past I have used Wood conditioner by MiniWax but Haven’t had much success with it. The edgegrain still absorbed too much of the stain. Waste of money IMHO
To make sure I get an even finish how should I prepare the surface prior to applying the stain? End grain is a real challenge.
Wanda
I would fill knots and other imperfections AFTER staining. The filler will not take stain the same as the actual wood, so you need to color it based on the stained wood under one coat of the top coat. (If anyone should market a product that will reliably take stain the same as the wood around it, they could make a fortune.)
Pine is very difficult to stain evenly, particularly if a dark color is desired. I would not use a stain, I would use an aniline dye mixed with distilled water. Dye penetrates more evenly, in particular coloring both early and late wood so you avoid creating zebra effects. It still can be a bit blotchy but much less than oil based stains on pine. As far as end grain goes, dye can still color a bit darker, though again not as much darker than pigmented stain. One easy way that works pretty well is to wipe the end grain with plain distilled water just before applying the dye. If it is still too dark, then you can wipe off some of the dye with water.
The darkness of dye is determined by how concentrated it is mixed, not how it is applied. Dye should be flooded on, though you want to avoid splattering it about or letting dye run down over bare wood. If such a thing does happen, just quickly wipe the dye over that area before it dries. Wipe off excess. Dye can often look awful after it dries and changes dramatically when the first coat of the top coat is applied. Consequently, it is very important to test the mix by doing full samples on scrap, including the top coat. -
