Is there an April Fool’s Day article this year?
Janet
Janet
Special April 1 items
Not sure if FWW has done anything, but Lee Valley has come through again:
http://www.leevalley.com/US/wood/page.aspx?p=69302&cat=1,42401
Watch the video
https://www.finewoodworking.com/item/45884/video-sneak-peek-of-new-groundbreaking-video-workshop-series
Now, this is woodworking at its best! ;-)
I don't know about an April Fools article but this one sounds like one
But it is ALL true !
The secret is the balance of two awesomely powerful forces
adhesive wear
and
abrasive wear
It has been recently discovered by Bell Labs Woodworking Bunker (the BLWB Division for short ) that there is an optimum self regulating and self sharpening plane blade geometry that has, until now, been over looked by modern crafts people. It has been theorized this geometry was commonly known and used by all craftspeople before the fall into the dark ages ( not the dark ages we are currently in but the one in the 6th to 13th centuries). How else could they do decent woodworking without Tormek sharpeners and or a full set of Shapton stones ? I know I could not . . . until know !
On hearing this combination of angles anyone not actually using it would think that the edge would be too weak to be durable and so dismiss it on the spot without testing it and so this , apparently, is the reason this secret combination has lain in obscurity for so long.
However . . . like the twenty pound bicycle that easily supports the two hundred and thirty pound rider at ground speeds approaching and even exceeding fifty miles an hour this plane blade geometry is a miracle of engineering that has reached a pinnacle of positively perfectly balanced forces.
Pre 6th century they didn't know the actual mechanics of it but they knew that if they used a back bevel of 15° and a bevel up angle of 15 . 5° the forces on the blade would exactly balance and so sharpen the blade through what we now know to be "adhesive wear". The flexible edge navigating the molecular structure of the wood like a fine phonograph needle.
What is more this works regardless of the wood species being cut. Some would even say irregardless of the wood species being cut but I am not ready to go that far without further testing in my own laboratory which is located in the SiLLYWRDS Divison of Bell Labs.
The edge is self regulating once the exact balance point has been reached; like the double-acting rotative centrifugal governor on a steam engine : an infinitesimal wear on the one side of the edge deflected it one way and the adhesive wear then caused it to veer back, then the cutting action caused it to return in ever smaller oscillations until a near perfect steady state is obtained.
It sounds counter intuitive but then so does the differential of the rush of air over the top and bottom of an air craft wing causing lift.
As a matter of fact that is a relatively similar effect.
NOW using this new miracle edge geometry the only time you sharpen with stones is to set up the 15/15.5 geometry, after that just use the blade and occasionally advancing the blade slightly once a week or so to make up for the loss of metal on the blade.
No more sharpening.
It's a MIRACLE !
For full details go to this link
http://en.wikipedia.org/wiki/April_Fools_Day
Self sharpening
That must be the same self sharpening principle that is beign used and advertised by Roto tiller Mfg's. ;-)
Long time ago, I read about a drag racer's engine which had rubber camshafts. As the engine revved up, the cams wore into a wilder and wilder grind, enhancing the performance.
My garden tiller's tines don't rotate that fast, though.
bent tools
I always love the Lee Valley and FWW April fools, but this year my six year old granddaughter beat them all with a phone call.
"Papa ! Go down to your basement ! All your tools are bent !"
"Oh my"
"April fool, Papa, I gotcha ! April fool !"
