Greets…new here with a question about alignment issues on an older (Craftsman) contractor saw. I’ve been using it with fairly good results for years…last week the bearings went bad – bad enough that the arbor also had to be replaced. Sears sent me a new arbor with one of the 2 bearing included.
I had a local machine shop procure the 2nd bearing and press them both into the trunnion. I aligned the trunnion as best i could by placing a blade on, setting my miter gauge in the slot just touching the edge of one tooth at the front – then checking for the same ‘just touches’ on the same tooth at the back. Then i tightened the 6 trunnion bolts and took a look at how the blade spun.
It had a horrible ‘wobble’. I took the blade back off and put a micrometer on the arbor’s flange. The up-and-down looked fairly good but the side-to-side deviates by .008.
Here’s the stuff i don’t know:
Since putting the micrometer on the top of the flange shows < .002 deviation but placed on the face of the flange shows much, much more, haven’t i learned that the shaft itself is true, but that the face is poorly cast/ground/milled…whatever the process. Or can there be a different explanation?
I don’t have a great deal of experience using a micrometer (read: any) so if there are important ‘to-dos’ involved i might be part of the problem. But it seems fairly straight forward.
Also….just how serious _is .008 deviation? Showstopper or within tolerances for an admittedly < fine woodworker?
thx
–steve…
Something isn't right...
Steve,
The face of the flange out at the rim is what affects whether the blade runs true side to side and your measurement, if accurate, is way off, most saws show either .000 or at most .001 run out. A run out of .008" would cause quite a wobble in the blade and will make accurate work impossible.
Without seeing your saw it is impossible to say why your flange is so far off, it could have been made incorrectly or it could have been damaged later either by being dropped or struck hard before it was installed or it might have been bent by inept handling when the bearings were being pressed on. The flanges on some saws are flimsy and more easily damaged than on other saws.
Presumably you are using a dial indicator not a micrometer to take your measurements.
