Hi,
I am trying(using router)to cut the cope and stick for the arc door, but having probem by breaking up at the end because the piece is to thin. I did clamp a scrap piece at the end but it didn’t help much. Also, this is a free hand cut, how do we control the amount of wood cutting. Thank you. vn.
From what I can tell,if a backing block is not reducing tearout,you're removing too much stock in one pass.Perhaps take three passes, a little bit at a time.
Important! Forgot to mention-do not try to freehand cut this with a router that is fixed to a table.Dangerous. If the stock is fixed,then you can freehand cut it,but exercise good control over the router.I would not recommend this method unless you clamp a block to guide the router,and remove a little each time as mentioned before.Good luck.
hi,
I clamped the work piece in a piece of MDF,then screwed tighted scrap pieces at each end. I did many passes, but after few pass the piece broken. I wonder should I using the clamp for the scrap pieces instead screwed them in, may be it help to back up better. Thanks.vn.
The rail, or piece,should be at least 2" wide.It's best as suggested to rout the ends first,then cut the arc.In other words,rout end grain then long grain.When using a cope and stick bit, I find it best to have the router fixed to a table and run the stock using a mitre guage in a slot, with a backing board.Freehanding from above means too much chance to move it out of plumb,destroying the cut.
Hi All,
OK. Start from the beginning. I am using PC7518, set at 13,000Rpm on the table. The piece is 4" wide and 2 1/4" at the arc. I cut the cope first, then cut the arc. After that I did the stick, and the problem was the end piece broke after the second or third pass. Also, burned marks appeaed at some place, my guess is probably I fed the piece too slow. The work piece was clamped in a piece of MDF for safety, and two scraps piece screwed to the MDf also at each end of the work piece (what I was trying to do is just slide the work piece between the scraps). If I am correct, I think I should clamp the scrap pieces to the work piece as well instead of screwed them in. I haven't done this yet since I am waiting to get some more help. Thanks. vn.
What I do is cope the ends of the piece before I cut the arch. You might want to cut the sticking in two passes, but I've never had much problem with blowout
