I’m joining 1-1/16″ x 6″ pressure treated boards cut 22-5/16 degrees to build an arch. The plans call for using a finger joint router bit for the butt joint. I am thinking of tongue and groove joints instead. Make sense? Any tips for getting the cuts accurate on the router table? Thanks, Todd
Todd,
Finger joints are used for end grain to end grain joints because they create a lot of side grain glue surface. A tongue and groove joint has very little side grain and will make a very weak joint.
Using a tablesaw, I'd cut a 3/8 inch wide, 1 1/4 inch deep open mortise on the end of each arch segment and glue in a spline of 3/8 inch thick PT wood. Run the grain in the spline in the same direction as the grain in the segments.
John W.
Edited 4/23/2004 5:18 pm ET by JohnW
I did something similar a couple of yrs ago making redwood arches for an arbor and a deck.
I used biscuits (4 per joint) and polyurethane glue (Gorilla Glue). After the glue up, I cut the arches on a bandsaw. (SWMBO agreed that I needed the bandsaw because she really wanted the arches).
I'm with John W.
I just did 1 1/2" deep 5/8" wide open mortises with splines on this arbor--it's a very strong joint.
Hey Eddie, what type of wood is that ? Very beautiful.
Hi Joe,
I'm Scott ;-) Eddie is the fella I built the arbor for.
It's 150 year-old Eastern Redcedar (ERC). I got the logs from a pre-civil war cemetary where they blew down in a storm last summer. It was unlike any ERC I've evr sawn before--most of the boards were 12"+ wide (10' long) and had very few knots or crumbling rot typical of the species.
Scott Banbury
http://www.scottbanbury.com
No wonder the stock looks so nice, and it's nice seeing urban trees going into projects instead of the landfill !
Well, upon your advice, I cut mortises for splines, now I'm ready to make splines. I assume using pressure treated wood is the way to go (though they shouldn't end up exposed). The mortises are 3/8" wide, so I'm trying to figure out the best way to make the splines. I suppose I could run the one inch board through a planer, but that's alot of planing. I don't have a band saw to resaw with. What do you recommend? Todd
