Recently (somewhere) there was a short discussion that dispelled many myths about “aromatic cedar” aka western red cedar aka other names. The bottom line, as I recall, is that none of these “cedars” are “cedar” but rather “junipers”‘.
Is there someone with a better memory for recent events that can point me to the “straight poop” on this? I’d sure appreciate it because the topic just came up again and I want to be sure I have my facts straight before “offering me two cents worth”.
(BTW Doc, if you’re reading this, thanks! The Meds are working wonders 🙂 )
— ok, I’m being a bit silly, but that’s my hard-earned perogative 🙂
— Steve
Enjoy life & do well by it;
it might well be the only chance you get.
Hey Steve,
"about "aromatic cedar" aka western red cedar aka other names."
I'm not sure about cedar vs junipers. I can tell you that "aromatic" cedar and western red cedar are not the same wood. Western red cedar can be purchased at the big boxes and just about any building supply. It is very popular for fence, outdoor furniture etc. Whereas aromatic cedar, also known as eastern red cedar, is what is used to line closets, build blanket/hope chests, make clothes hangers, etc.
I use the ERC quite a bit. I have build some outdoor stuff with it, but you have to use full 4/4 or 5/4 to get the strength. It is very brittle and not as strong laterally as the WRC.
ERC grows here in MS all over the place, I have two small logs right now waiting to go to the mill.
Though I lived out west and in the mid west I not sure I ever saw a WRC growing. So not sure if they are similar or not. Well there's my .02. Good luck
Jimmy
as always I wish you enough.
Steve
Eastern Red Cedar aka aromatic red cedar, is juniperius virginianus, or something like that so yes, it is a juniper. For some strange reason, I remember this from 5th grade shop class. It is not the same as western cedar, which is the kind that fences and roof shingles are made of. The eastern version is definitely not wood that you can use outside. In fact it is a PITA to work with, even if it is pretty. It's considered an invasive species around here, and grows like a weed.
Stan, I don't know how you can make the statement "The eastern version is definitely not wood that you can use outside. In fact it is a PITA to work with, even if it is pretty."
I have some wood that I found that has about 500 annual rings. It had been dead since 1945, and I found it in 1990, and there is no rot present in it.
How good does it need to be to meet your approval, and what makes a soft even texture wood a PITA to work?
rootburl
sorry, I didn't mean to insult it. I like the way it looks and smells. Heck, I still have the cedar pen & pencil holder I made in that shop class. But every time I've used it for a project, I've had problems with splitting, tearout, splintering, etc. I just gave up on a hope chest project after having two glued-up cedar panels break in normal handling. I think the general absence of cedar being used in fine furniture speaks for itself.
Just my experience, and I have no doubt that in the hands of a more skilled and experienced wworker, it can be worked effectively.
I was speaking of eastern red cedar only, BTW.
Edited 2/27/2005 9:59 am ET by stantheman
Correct both species are not true cedars. Western Red Cedar,Thuja plicata and as posted above Eastern Red Cedar is Juniperius virginian (sp).. Most ERC is used for corner fence post around here. Working ERC is easy and sweet but it does tear out badly and crack alot across the knots and as previously noted it is very brittle.
Invasive species is the new word for ERC. I refer to that statement as poor pasture managment and also to good fire control. The results: ERC out the wal-zoo....Another thing Uncle Sam will throw money at due to the 'squeaking wheel gets the grease' effect.
I think(??) true cedars are Cedus genius... Without looking that up I would not stand by that hunch....Dale
<<I think(??) true cedars are Cedus genius... >>Close, I think what your trying for is "Cedrus". Alaska Yellow Cedar, White Cedar and the famous Port Orford Cedar (yellow cedar) are examples.Ironically, they are all quite aromatic, but are not THE aromatic cedar of blanket chest fame, that's ERC, the juniper.Tom
Ya, ya, that's what I meant, my spelling got in the way, : ' ) ....Thanks for the correction.......Dale
Thanks to each of you!
Collectively, that's been a *great* help in unwarping my feeble memory :-)
As I was typing out my original plea for help, the only image I had in my mind's eye were the "infamous" Cedars of Lebanon -- and I *knew* those weren't the "critters" the others were refering to.
THANKS(!) To Each of you!!! I truely appreciate your help :-)
-- Steve
http://www.ApacheTrail.com/ww/
Some info on aromatic cedar came up in a thread I started, asking about juniper. Here's one quote:
Then, just to make things interesting, there's the confusion between cypress and cedar. Here's a quote from our very own Jon Arno:
