I have been working with Riff sawn Oak and I keep getting STRANGE problems with it. DOES NOT HOLD A GLUE JOINT!
Any opinions to offer? And tips using it.
It seems to do it’s own thing…
Will ,
Did I remember you saying you even used Titebond 3 er sumthun like that ?
Unless you have a moisture problem beyond normal my hunch is the glue .
I use regular old Titebond 1 aliphatic resin glue and have run miles of Rift ,my favorite without glue failures , so I know you'll figure it out .
Just to see if you haven't try a sample with tb 1 and do your break test .
Are the joints in question edge grain or face to face ?
how was the mating surfaces made flat ?
dusty
edge grain to edge grain and using Titebond II..The glue is holding onto the wood. The wood fibers pull out.Just a question I had because I do not use Riff sawn that much. This only seems to be a issue on small glue areas. QS and flat sawn seem to hold together much better.Edit: I'll get some Titebond I and see.. Thanks..Edited 10/21/2007 8:23 pm by WillGeorge
Edited 10/21/2007 8:24 pm by WillGeorge
If you still do not succeed, give hot melt animal hide a try. I have been using a glue pot recently, and so long as there is enough water and the wood is warmed and clamps are left overnight, then I have not been able to separate the trial glue-ups.
No good for damp conditions though.
Dusty may be on to something. If your dried glue looks white or chalky it may have gotten too cold. Try fresh glue.
Paul
