I’ve just learned that here in San Francisco I can get ash for roughly half the cost of maple, $2.84/bf for 4/4 and $3.96/bf for 12/4. Has anyone built a benchtop from ash?
As a former ballplayer, I think it’s almost fate that this is looking like the best wood for this job…
This discussion has occured here before. Do a search for workbench and ash.
I was one of the ones who strongly encouraged the poster to use ash. I have made lots of ash furniture. It will serve you well as a work bench. However, it will be difficult to swing at any fastballs.
Rich
I was sure someone had posted about this before, but couldn't find it by searching. Thanks for accommodating me and confirming my suspicion that ash will make a great bench.
And you're right, the biggest bats I ever used were 34"/31oz'ers. I think 80"/16000oz would make it tough to foul off the inside heat.
The search engine is being weird again. Here's a big ash bench thread:http://forums.taunton.com/fw-knots/messages?msg=31476.1
Search tips: always use "advanced search" The other search function must be just for show, LOL. If "workbench" doesn't work (I got zero hits) try simply "bench." Final, and most important tip: Prayforestgirl -- you can take the girl out of the forest, but you can't take the forest out of the girl ;-)
Apparently, maple makes a great baseball bat too.
Years ago I made a trestle table for our dining room out of ash. It is very dense wood and think it should work well for a workbench. I was very concerned about the “open grain” when compared to maple or birch, but I put a lot of coats of Deft lacquer on it and the wood sealed up nicely. I’m planning to use the table as an assembly table in my new workshop when I get it set up.
I have two benches made of ash. It is very hard, doesn't move much and stays fairly flat. I scrape mine off twice a year and put formby's "tung oil" on it to keep glue drips from sticking.
Frank
Very serviceable, but like all wide surfaces, provisions for seasonal changes are essential.
Routers
Edited 1/31/2007 11:48 am ET by Routerman
I had posted this same question last year...I came into a lot of ash that I wanted to use for a workbench.
I got differing opinions from "yes, definitely no problem" to " no way, it will splinter" , etc.
I am using the Ash for the base and Beech for the top.
Though it is my opinion and experience that Ash will be fine.
To prove it, I made a mallet out of the same Ash and used it to knock on the end of my Hirsch mortise chisel as I made 40+ mortises for a set of tables.
It didn't splinter at all and it dented very mildly -- the thing took a beating with very little "damage".
Go for it, use Ash....besides it is very heavy!!
good luck,
erik.
I shudder to think of what you'd have to do to an ash bench to make it splinter. ?split firewood on it?
Frank
Hi Rob,
I built a workbench out of ash last summer and am very happy with it. I used shellac to finish it. This kept the wood light coloured and easily repairable. No problems with tooling it either (splintering, etc.).
I left the bottom open to allow room for a tool chest at a later date. The dimensions of the top are 28 x 72".
Nathan
Nathan,
That's a very nice bench. Thanks for the information. I may have to consider ash since I have a lot of past experience with it.
Nathan,
That's a beautiful bench. Very nice work. Are the legs solid pieces or glued up?
Maybe this will end doubts about ash as a suitable workbench material.
Rich
Thanks Rich,
The legs are glued up (two pieces of 8/4 ash). I used 8/4 ash for everything. The base joints are is mortice & tennoned with the strechers being held together with carriage bolts for disassembly.
This was a fun project and I have often thought of doing another one for resale to see if there was a market (locally).
Wow. Just wow.
