I’m close to finishing my 1st workbench but I’m seeking some advice. I want to attach apron to workbench. Theres opposing grain. I’ve seen one guy cut a rabbet and use a spline. I’ve also seen someone bolt the apron to benchtop. I was thinking of using a Domino and attach. I don’t want to overcomplicate this however I want to do this correctly. Any help is appreciated!!
Can you share a sketch or even a photo of what you are trying to do?
Attached is a picture taken directly from my Veritas installation manual. I want to attach my apron to my worktop exactly as they have it shown here. However they don't mention on how to attach. I thought of simply using dominos and glue. There is opposing grain though. I actually thought of attaching it like a breadboard with loose tenons. I'm fairly new to this type so I want to be sure I do it correctly
It would help to know how the top is constructed. If laminated side to side boards, there will not be much movement. If wide, flat boards, there maybe appreciable fluctuation.
The simplest solution is a center fixed lag bolt with outer elongated holes.
I have used a center lag bolt and dovetailed ends into side front and rear aprons, Alternative is breadboard end construction, but I do not think this is necessary for a workbench.
Mine is glued and screwed along the sides, the ends are bolted in slightly oversized holes.
Hey,
Sounds like personal preference. Remember, woodworking's supposed to be fun, not excruciating labor.
Mikaol
*If you love what you're doing you'll never work a day in your life* Einstein, I think.
I think this is the same twin screw vice that I used on my bench and the grain has to be running in the same direction or the vice jaws will twist out of square . Good luck though and enjoy your bench ,it’s the most important tool in the shop imho.
There is no "opposing grain". You can glue the apron to the benchtop directly.
Yup. Just glue it to the bench, just the way it looks in the picture.
The manual shows the apron bolted on in several of the diagrams. Lee Valley supplied barrel nuts, washers and bolts for this with my 2 twin screw vises. My top is laminated ply and MDF so I just glued the aprons on.
